dt466e dt530e injectors, whats the diff - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 12-29-2009, 04:59 AM Thread Starter
TRUBBS's Avatar
what are the diffrence between the 2 and would they both be able to be put into a 7.3 with good results? with proper mods? the dt466e is inj code ba and the 530 is code bn
TRUBBS is offline
post #2 of 5 (permalink) Old 12-29-2009, 11:17 AM
PowerHungry's Avatar
Re: dt466e dt530e injectors, whats the diff
There have been people that run the B-Codes quite often. The first difference is the injector spray angle is completely different so you'll have to replace the nozzles in order to be able to hit the bowls properly.
The rest can be explained here...
Injector Info - Powerstroke Nation
Enjoy.
PowerHungry is offline
post #3 of 5 (permalink) Old 12-29-2009, 08:34 PM Thread Starter
TRUBBS's Avatar
what about code bn code injectors? i didnt find nothing about them in that post
TRUBBS is offline
post #4 of 5 (permalink) Old 12-29-2009, 08:47 PM
HRT Performance
HotRodTractor's Avatar
BN injectors use a stainless steel compression gasket instead of the copper found on most HEUI injectors. This was because they changed the injector cup in the head from a brass to a stainless steel for some applications. I do not know any other specifics other than the stainless steel gasket is to be used with the stainless steel cups.
2006 Dmax MPI compounds
2015 VW Jetta TDI
2006 VW Jetta TDI
HotRodTractor is offline
post #5 of 5 (permalink) Old 12-29-2009, 09:10 PM
You may have missed it... It was the last line in the post.
EF, BG, BI, BJ, BN and BP injectors all have basicly the same capacity and are split shots. However the nozzles vary on them depending on application. They can be found in many DT466s and I530Es.
