Re: Tricky performance question for all you #'s guys
A more basic way to say what I was getting at above....you want the exhaust housing to be the restriction in the system (nothing before or after), this will cause the gas to expand/excelerate in the housing.
So this means you want a consistant size of feed ALL the way to the turbine, then after the turbine, the bigger the better to allow rapid gas expansion and cooling. The cooling will further excelerate the process.
2008 F-250 SCLB Larait.
