turbo question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 12-27-2009, 05:16 AM Thread Starter
turbo question
I found a new rebuilt turbo with a banks ww and a van exhaust housing, but theres no mounting for the wastegate. I was told by someone that you don't need one, but i thought that's something you need whether it's internal or external. I would like some input before i buy. Also is it a good idea to use a delete pedistal to remove the exhaust back pressure valve. My engine lights on and has this code. Thanks for any input!!
bandit700 is offline
post #2 of 5 (permalink) Old 12-27-2009, 10:48 AM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
Re: turbo question
you mean the exhaust back pressure valve (EBPV)...no its not needed...you can delete your pedistal or buy one if you got the spare cash..if you delete yours...make sure you unplug the wire at the pedistal....
Ron's power stroke is offline
post #3 of 5 (permalink) Old 12-27-2009, 03:22 PM
Caption This
444-4D's Avatar
Re: turbo question
Vans didn't use one. 94-97 PSD engines didn't use one. Super Duty pickups use them because the turbine housing is too small to be used without one.
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
444-4D is offline
post #4 of 5 (permalink) Old 12-27-2009, 03:52 PM
<----Colin Banks
mattymx's Avatar
Re: turbo question
The van housing does not need a WG and is a really good upgrade for a stock super duty. But why on Earth would someone put a WW on a turbo with a van housing? THat is retarded! That turbo should have a stock super duty wheel on it. BUt it's not that big of a deal.
mattymx is offline
post #5 of 5 (permalink) Old 12-27-2009, 09:10 PM Thread Starter
Re: turbo question
Thanks everyone for the info. It's nice to get answers to things i'm not sure about. I'll get the turbo and a delete pedistal for the ebpv.
