My Turd at Bandimere - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 26 (permalink) Old 08-01-2007, 01:44 AM Thread Starter
15.79 bad exhaust leak, would NOT spool, bouncing off rev limiter in 1st
http://videos.powerstrokenation.com/...7a001f3442.htm
15.09 bad exhaust leak, set on pre stage til she spooled this time, still bouncing off rev limiter. This was actually launching in my 100 setting then swtich to extreme after 1-2 shift finally happened.
http://videos.powerstrokenation.com/...7a001ad729.htm
I did another slow run like 15.59 but no vid.
I had to let off both times and get back into it before the 1-2 would complete.
We are tweaking shift points, different valve body, and *hopefully* live tuning, then I'll get back on the slab.
gregrob is offline
post #2 of 26 (permalink) Old 08-01-2007, 01:46 AM
AllYourBaseAreBelongToUs
imelmo's Avatar
Re: My Turd at Bandimere
Does something with altitude make 'em bounce off the rev limiter? Mine was doing that like crazy at the DPC in Utah but we figured it may have been the transfer case chain getting loose and slipping or something. Wasn't doing it at Bowling green.
EMPIRE DIESEL, PERFORMANCE TRUCK PRODUCTS, CEN-TEX DIESEL PERFORMANCE, AND DIESEL INNOVATIONS
ALSO LOTS OF HELP FROM (IN NO PARTICULAR ORDER) TWISTED DIESEL PERFORMANCE, FCDP, ITP, MATT WITH GEARHEAD, ERIC WITH INNOVATIVE, DOUG WITH GOGO DIESEL, CASS WITH FULL FORCE DIESEL, AND SWAMP'S
2005 F350 Fat-Butt Truck
2004 ECSB Procharged F250
imelmo is offline
post #3 of 26 (permalink) Old 08-01-2007, 01:48 AM
RDRCM
CooterBrown's Avatar
injectors, oil and 4wd? 15.09?
#49
Sold
2006 Almighty CumminGs
CooterBrown is offline
post #4 of 26 (permalink) Old 08-01-2007, 01:52 AM Thread Starter
You know that's a good question elmo. I think this is a tuning/shift point issue in my case though. Something Jody and John Wood ran across when Jody was in CA. Just need my tunes updated since then.
yes sir, 180cc's w stock nozzles, terminator, and 4x4.
I really think it has a mid/low 14 in it. It's just way stronger on the street than a 15.xx truck.
Gene told me if his 6.0 hits the rev limiter 1 time, it was second. I know stroked lightning is a good bit faster, but the theory is the same. hitting the rev limiter, lifting all the way off the throttle, losing boost, and getting back in it = not good for 1/4mi times.
There is a track that is close to 4500ft elevation, I'm gonna get on that when I get the up pipes, valvebody, and tuning done.
gregrob is offline
post #5 of 26 (permalink) Old 08-01-2007, 01:54 AM
greenbeast's Avatar
maybe its just to heavy.
greenbeast is offline
post #6 of 26 (permalink) Old 08-01-2007, 01:54 AM
RDRCM
hmm
My truck has stock injectors, iddy biddy oil, GTP38R, SES at half track and 2wd
60'............... 2.358
1/8.............. 9.83
mph..............71.xx
1/4...............15.38
mph..............87.88
You need to send some money wildmans way!
#49
Sold
post #7 of 26 (permalink) Old 08-01-2007, 01:55 AM
greenbeast's Avatar
good tuning goes a long way!!!!
post #8 of 26 (permalink) Old 08-01-2007, 01:56 AM Thread Starter
hmm
eh, I would own you on the street
we'll get er tweeked and back to the track.
EVERYTHING was against me, low boost because of exhaust leak, wouldn't shift, wouldn't spool, yadda yadda yadda
gregrob is offline
post #9 of 26 (permalink) Old 08-01-2007, 01:57 AM Thread Starter
Yep
gregrob is offline
post #10 of 26 (permalink) Old 08-01-2007, 01:58 AM
imelmo's Avatar
I was smacking the crap out of the rev limiter on the 1-2 and hittin' it pretty good on the 2-3 and went from a 12.18 @ 111.71 to a 12.8? @ 107.?? .
imelmo is offline
