17 and 19 degree hpop whats the difference? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 12-26-2009, 03:14 PM Thread Starter
dadozer's Avatar
whats the difference between the 17 and 19 degree high pressure oil pump?
2003 F350 7.3L CCLB 190k
29.5 lpm injectors, MBRP 4" turbo back exhaust, Tunes by Matt from Gearhead! WW, DIY intake w/ 6637 filter, leveling kit, Autometer guages
dadozer is offline
post #2 of 14 (permalink) Old 12-26-2009, 03:24 PM
Here for the party....
Re: 17 and 19 degree hpop whats the difference?
2 degrees........
2015 Chevrolet Tahoe, Crystal Red Tintcoat, LOADED
2014 Ford Mustang GT, 5.0, Race Red, 6 speed
Currently Stroke-less
Al Mighty is offline
post #3 of 14 (permalink) Old 12-26-2009, 03:24 PM
One can supply more oil. Who made the 19 degree pump?
bigjake0524 is offline
post #4 of 14 (permalink) Old 12-26-2009, 03:27 PM
tank's Avatar
You mean what's the differance between a 15* and 17* hpop.The awnser is the 17* will move more oil. From what I have seen the 17* will hold about 300-500 psi more than the 15* at wot with stock ad injectors. Disclaimer your results may differ.
E99 F250 CCSB 6 pos chip Gearhead Auto
Swamps 250/80 hybrids ARP head studs DI pushrods Comp 910s Adrenalin hpop ceramic coated 38r and up pipes complete fuel system + regulated return water/meth full built trans PI converter JW vb afe2 intake and afe bladerunner 3" intakes 4" tb exhaust 6.0 tc pmt 1 boost egt + scangauge
tank is offline
post #5 of 14 (permalink) Old 12-26-2009, 08:54 PM
urbanwheeler's Avatar
there is a modded hpop that is 19* or 20*. i am running one from joey, not really impressed with it. it is one of the first ones he did and i guess he can fix the extended start problem that the first modded pumps had.
'96 f-250, auto, shackle flip, solid axle, rsk, high/crossover steering, 3.73's, true trac's front and rear, trac bars, gt4202, 7.3 ic, idm mod, ccv mod, A1000, 4-line DIY Gen3, dual ipr's, casserly 350/200's, arp studs, 910's, pushrods, elec. fan, 2-stage nitrous, fluidampr.
[SIGPIC][/SIGPIC]
urbanwheeler is offline
post #6 of 14 (permalink) Old 12-27-2009, 12:22 AM Thread Starter
dadozer's Avatar
I'm sorry I meant 15* and 17* thanks for all the great info. If I had one starting to go bad would it give me trouble starting cold?
dadozer is offline
post #7 of 14 (permalink) Old 12-27-2009, 12:52 AM
Probably not, but if that's the story you have to give your wife to justify a 'new' one, I don't think anyone will tell on you
YellerMax is offline
post #8 of 14 (permalink) Old 12-27-2009, 02:04 AM
if the hpop is going bad how would it create the right amount of psi in order to start?
02 f250
countryboyrob is offline
post #9 of 14 (permalink) Old 12-27-2009, 02:29 AM
Grant, I don't mess with swash plates, it effects pump reliability. Yours is still a 17. If/when you have some down time, send it down and I'll update it for free, I think....................
TerminatorEngineering is offline
post #10 of 14 (permalink) Old 12-27-2009, 03:55 AM
I suppose it's possible, but I have never heard of it. I'm certainly not an expert, but from what I do know of how the HPOP and HEUI in general functions, a few things...
1) So little ICP is used to idle, that if your HPOP is not producing adequate pressure it is much more likely to manifest at WOT and high RPM than at idle loads
2) I'm not sure that it is something that would gradually wear out. Isn't it a piece of equipment that is going to just stop working altogether, vice gradually lose effectiveness like a consumable (say, an alternator)? Other pumps, like power steering, water pumps, hydraulic pumps, etc... tend to just straight sh*t the bed
What are a few of the more likely candidates?
