I HATE QUICK CON. FUEL FITTINS! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 12-26-2009, 03:29 AM Thread Starter
TRUBBS's Avatar
dang fuel line quick connects are a major pita! first i couldnt get the [email protected] things apart without breaking 3 of the special tools and now my blue hose one it being a b!tch at staying on. blew off the very second my truck first fired up with the new motor, then the dang thing has came off 2 times while driving down the road! i know it was locked in cuz i felt it "pop" when i put it in and even tried pulling it back out and it wouldnt come. now i got it in and zip tied the fuel line solid to the fram rail so it can vibrate around lol.
not b!tching or nothing cuz its way easy to fix, jsut sharing my experience with y'all
on a side note i sure do love having my truck back!
TRUBBS is offline
post #2 of 12 (permalink) Old 12-26-2009, 03:32 AM
Don't EFN worry about it
Aljay's Avatar
Re: I HATE QUICK CON. FUEL FITTINS!
Might need to change out the inside of the quick connect,ford sells them.
Tuned by T Wildman
Aljay is offline
post #3 of 12 (permalink) Old 12-26-2009, 03:34 AM
All done now
Arisley's Avatar
When mine fail, I will just go to hose and double clamps.
Arisley is offline
post #4 of 12 (permalink) Old 12-26-2009, 03:35 AM
just a welding fool.
Hawker's Avatar
i got rid of mine and went with double clamps. heard that the stock fittings let air into the line.
Swamps
Gearhead Tuning
Diesel Innovations
Hawker is offline
post #5 of 12 (permalink) Old 12-26-2009, 04:10 AM
All done now
Arisley's Avatar
Only on the suction side (pre-pump). They actually do a really good job on the pressure side.
Arisley is offline
post #6 of 12 (permalink) Old 12-26-2009, 12:31 PM
DZL JIM's Avatar
I stumbled across a billet alum. fuel coupler tool at a swap meet, waaaaaaaaay better than the cheap NAPA tool. I stuck it in there and before I could think what to do next the fitting fell off. When you monkey with the tools you ruin the tabs inside. I wish I knew a place to get more of these things, but the guy only had 5/16 and not 3/8 and I have no way to reach him now. Tool was $2.50.
DZL JIM is offline
post #7 of 12 (permalink) Old 12-26-2009, 01:41 PM
All done now
Arisley's Avatar
Sorta like these.
Performance Tool Master Deluxe Line Disconnect W89338 | Fuel Line Tools | Northern Tool + Equipment
Arisley is offline
post #8 of 12 (permalink) Old 12-26-2009, 02:37 PM
Aljay's Avatar
A set off the mac truck both alum. and a set of nylon. Yes the fingers get jacked inside sometimes from build up sometimes from improper use.
I spray them with wd 40,makes them alittle easier to get apart.
Tuned by T Wildman
Aljay is offline
post #9 of 12 (permalink) Old 12-27-2009, 03:27 AM
PSN Pretender
907DAVE's Avatar
Sooo..............its running again?
907DAVE is offline
post #10 of 12 (permalink) Old 12-27-2009, 06:45 AM
Village Idiot
southmike's Avatar
not until he tightens the loose nut behind the wheel......
southmike is offline
