Measuring drive pressure - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 12-24-2009, 05:51 AM Thread Starter
What is the best way to do this? Do you just use a boost gauge or is there a special gauge for it? Does it need to be close to the turbo, like in an up-pipe?
bigjake0524 is offline
post #2 of 14 (permalink) Old 12-24-2009, 06:01 AM
ELKHUNTER's Avatar
Re: Measuring drive pressure
Scangauge reads off of the back pressure sensor, way simple compared to plumbing.
Josh
2000 F350 205,000
STAGE II SPLITS 100%
STEALTH SRP1
TYRANT TUNES
38R TURBO
BTS VALVE BODY
WALBRO 392
SCANGAUGE
ISSPRO
MORE STUFF
ELKHUNTER is offline
post #3 of 14 (permalink) Old 12-24-2009, 06:04 AM Thread Starter
Maybe, I'll just get a hold of terminator than. Does this work if I'm running a different turbo mount other than stock?
post #4 of 14 (permalink) Old 12-24-2009, 06:04 AM
OverFuelingForYourPlesure
pontiacross's Avatar
only problem with the scan guage is it maxes out at about 40psi iirc
I have a regualar old boost guage plumbed in one of the uppipes.
to keep the heat and soot from messing up the guage I took a piece of 1/4 copper tubeing about 4ft long and twisted it in a cork screw. then hooked one end to the up pipe and the other to the guage hose.
Ross
2.6 modified street pulling truck "The Lone Stroke
-1996 f350, stock bottom end! swamps 400/400% injectors, swamps BFH turbo, swamps IDM, Swamps tunes, BTS oil, springs, studs, tubes, fuel system, water to air cooler, and much more...
-97 f350 4x4 CCLB tow rig
pontiacross is offline
post #5 of 14 (permalink) Old 12-24-2009, 06:07 AM Thread Starter
Thanks, so I should have a boost gauge that reeds higher than 40. Guess I shoulda had Swamps send out two of them..
post #6 of 14 (permalink) Old 12-24-2009, 02:13 PM
I am using the Performax gauge now. Before I had a regular boost gauge and it bounced around a lot. I heard that you can use a snubber to keep a regular gauge steady though.
99 F350 CCLB
skav is offline
post #7 of 14 (permalink) Old 12-24-2009, 02:37 PM Thread Starter
Does a snubber just go in line to block surges. Where can a guy get one or can it be made?
post #8 of 14 (permalink) Old 12-24-2009, 03:12 PM
I would talk to a vendor, but I'm pretty sure that ISspro and Auto meter both offer one.
99 F350 CCLB
skav is offline
post #9 of 14 (permalink) Old 12-24-2009, 03:39 PM Thread Starter
Thanks, I'll get ahold of em after Christmas.
post #10 of 14 (permalink) Old 12-25-2009, 03:15 AM
where is your guage plumbed in at? mine dosent bounce at all, I wonder if haveing it close to the turbo helps that?
Ross
