Oil Feed From HPOP Resivoir - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 12-22-2009, 10:31 PM Thread Starter
Got Bost???
NyCowboy87's Avatar
Any reason or drawbacks feeding oil to the atmosphere charger from the hpop res? I have a gen3 style pump with the old style t444e resivoir and it has plenty of holes in it to feed the charger and run an auxillary feed line to.
95 Ex. Cab Long Bed 4x4. Built.
01 Ex. Cab Long Bed Dually 4x4 6 Speed. Intake, Exhaust, Super Chips Tuned
Tow Mule
NyCowboy87 is offline
post #2 of 8 (permalink) Old 12-23-2009, 03:56 AM
What else?
smokyred's Avatar
Re: Oil Feed From HPOP Resivoir
I don't see why not, on IH school buses they run an oil feed line from the HPOP resorvior to the air compressor.
As long as you have an aux. feed line like the Gen3, I say go for it.
Dave
smokyred is offline
post #3 of 8 (permalink) Old 12-23-2009, 06:08 PM
<-- it's like that
Am I crazy or does the oil to the HPOP reservoir bypass the oil filter?
If so, could that be a concern for a turbo spinning at 100,000 rpm's?
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's.
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the
Pocket is offline
post #4 of 8 (permalink) Old 12-23-2009, 08:01 PM
DZL JIM's Avatar
I always thought that, too, oil goes right from the pump up to the HPO res, BUT all the oil gets filtered eventually anyway.
As long as you have an aux supply to the HPO res you'd be fine. Then again, you could just run the aux feed line to the charger.
You do not want to pull more oil from the res w/o additonal feed to it with a Gen3 type pump.
DZL JIM is offline
post #5 of 8 (permalink) Old 12-23-2009, 10:19 PM Thread Starter
Got Bost???
NyCowboy87's Avatar
True, never thought about that. The main reason I was wanting to do it was to try and keep from having lines running all over the engine bay as there is no place to tap in for oil on the passengers side.
Tow Mule
post #6 of 8 (permalink) Old 12-23-2009, 10:44 PM
Sponsor
IMHO It would be best to keep all the oil going to the reservior reserved for the injectors... Some breeds are very oil hungry... You can easily use one of the ports from the drivers side and run the hose over.
UNLIMITED_DIESEL is offline
post #7 of 8 (permalink) Old 12-23-2009, 11:00 PM
Pipewhiner's Avatar
I would do that too, Jake. People add auxillary oil feeds to the HPOP area for a reason, not cuz there's a bountiful supply of oil to be had there.
1999.5 Brugundy/Black CC 4x4 Dually BTS, IH DTA360 conversion completed
Pipewhiner is offline
post #8 of 8 (permalink) Old 12-24-2009, 04:17 PM Thread Starter
Got Bost???
NyCowboy87's Avatar
Alright thanks guys, I guess Ill just keep the feed line I had going from the 1/8" pipe plug on the side of the block.
Tow Mule
