V-Clamp Muffler? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 12-22-2009, 02:24 PM Thread Starter
3YLSYKR's Avatar
V-Clamp Muffler?
I'm wondering if I can buy v-clamp ends to be welded on to my exhaust and muffler. I wanna set it up this way so that I can run straight exhaust with no muffler, then for emissions just to be safe, throw the muffler back on. This would seem to be the easiest and simplest way to do so, just switchout straight pipe with muffler.
Anyone here run anything like this? If so how do you like it and post a pic if you got it please. I like the sound of my Magnaflow muffler and it is straight through with baffle but wanna run straight pipe whether I gain anything or not, which I'm pretty sure I wont other than noise.
8" Lift
38" Toyo MT's
DIY Traction Bars
Zoodad-AIH Delete-Foil Delete
Adjust. Wastegate
ISSIPRO Performax Gauges
4" TB Magnaflow Exhaust w/ 5" tip
AFE stage 2 PG 7 W/Pre-Filter
Superchips Prgmr 150HP/225TQ
Oil X-over Line
Smoked Lights w/LEDs & HIDs
DIY 3 stage Water/Meth
CCV
6.0 IC
Transgo Shift Kit
Derale Trans. Frame Rail Cooler
3YLSYKR is offline
post #2 of 5 (permalink) Old 12-22-2009, 06:56 PM
dinnerbooter treasurer
genuineford's Avatar
Re: V-Clamp Muffler?
I have used the V-band flanges from this site, but they only go up to 4 inch. If you do a google search you can find lots of them that are larger.
93 F350 Gasser
03 F250 6.0
dinnerbooter #3
genuineford is offline
post #3 of 5 (permalink) Old 12-22-2009, 09:36 PM
HRT Performance
HotRodTractor's Avatar
Up to 5" in mild steel can be found here:
http://www.racepartsolutions.com/products.asp?cat=106
2006 Dmax MPI compounds
2015 VW Jetta TDI
2006 VW Jetta TDI
HotRodTractor is offline
post #4 of 5 (permalink) Old 12-23-2009, 04:01 AM
What else?
smokyred's Avatar
I have that type of flange for the middle part of my downpipe, some pics are in my webshots. I got it off of eBay, the company had them in stainless, carbon steel, and aluminum. They also had the option of an o-ring for if you were using them in apps like intercooler piping and the prices were very reasonable.
Dave
smokyred is offline
post #5 of 5 (permalink) Old 12-23-2009, 04:25 AM
Grumpy Old Bitter Bastard
389SixPack's Avatar
Here is where I buy all my stuff in Stainless
http://www.burnsstainless.com/Hardwa...ps/clamps.html
aka - Grumpy .. aka - Bubba Grump .. aka - Bubba .. aka - Grumpy Old F... . . A "slow" fatass 9K Dually.
389SixPack is offline
