Fire rings Please help!!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 12-22-2009, 12:34 AM Thread Starter
ok guys looking for options. I dont know if the cometics are going to seal. so who is running Fire Rings? I talked to a few people and they clam fire rings hold well over 100lbs of boost. I wont be running anything near that but Im just looking for options. One of the main reasons i like cometics is if it goes You can still limp the truck home. If the fire rings go you are stuck!!!
USAF TSGT Retired "Medically"
99.5 CCSB 4x4 built motor and BTS
99.5 EX Cab Long bed with mild mods and BTS
Big thanks to Swamps Diesel and BTS!!!
randylamarr is offline
post #2 of 10 (permalink) Old 12-22-2009, 05:03 AM
HP Junky
Re: Fire rings Please help!!!
If the machine work and installation is done correctly, you'll never have a problem.
RockinJW is offline
post #3 of 10 (permalink) Old 12-22-2009, 06:20 AM
<< wasted fuel >>
haulin99sdp's Avatar
haulin99sdp is offline
post #4 of 10 (permalink) Old 12-22-2009, 06:31 AM
Have you had a problem with the Cometics? Or just worried about the what if? As long as your block and heads were prepped correctly than I don't think your going to have a problem with them.
bigjake0524 is offline
post #5 of 10 (permalink) Old 12-22-2009, 12:05 PM
Sponsor
His Block and Heads are perfect but he did have a problem with the Cometics... He's in the same boat that I was a few months ago. Only he's only blown one and I blew three, all within 1,000 miles of each other. I am having doubts that mine was actually an imperfection in the block, but something else. I can't pinpoint it, but I feel for you because it is a hard desicion to make. It took me a month of back and forth before I figured out what my next step was. According to others, Randy's block and heads look like pure sex, but there is some reason that the gasket failed... that has yet to be determined as far as I know. Its in good hands, but I think I'd fire ring it and never look back. I know where there is a plate and a cutter if it needs to make its way to Tennessee...
UNLIMITED_DIESEL is offline
post #6 of 10 (permalink) Old 12-22-2009, 12:42 PM Thread Starter
thanks nate!!! You are correct I did have a failure!!! and I dont want to have a bunch of failures. My truck is in very good hand at swamps so im not worried about that.
post #7 of 10 (permalink) Old 12-22-2009, 03:37 PM
That is crazy. Sorry for the bad luck. Makes me want to fire ring my heads now before they go on!
post #8 of 10 (permalink) Old 12-22-2009, 04:01 PM
Banning Smut
PTSUPERD's Avatar
His bad luck????? Just mine that he inherited.
J/k Randy. You know you're covered. (in good hands)
PTSUPERD is offline
post #9 of 10 (permalink) Old 12-22-2009, 04:03 PM
Fat Kids Rule!
House's Avatar
Send a message via AIM to House
Mine will be getting Fire ringed!
Joe "House" Kupferschmid
1995 F250 7.3 2.6 zf6 Puller
2006 Chevy 3500 CC DRW LBZ, Tow Slut
SOLD:2000 F350 harvester of sorrow
House is offline
post #10 of 10 (permalink) Old 12-23-2009, 12:39 AM Thread Starter
well greg i just dont know what swamps wants to do!!! I talked to the guys at cometic and they said tolerances should be within .002in and surfaces should be finished with at least 50ra im sure the machine shop did all this but the cometics still failed as they did 3 times on Nates motor.
