turbo ?in - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 39 (permalink) Old 12-22-2009, 12:19 AM Thread Starter
powerstroke02's Avatar
turbo ?in
goin to be gettin some sticks soon. so go with the 38r or go with a stock turbo with the high flow outlet 1.00a/r non ebv and ported housing or something better?
2002 psd,4x4 ECSB
DP-TUNED
4" lift 35" tires
3.73 gears
cervinis 3" cowl hood
fuel pressure-pyro-trans-boost
Full 4" exhaust
K&N fipk
Strictly diesel "bowl delete" regulated return
FASS system
cutsom built trans
stealth stage2 (big oil)
di's up pipes
38r with wicked wheel 2
6.0 trans-cooler
ccv moved
swamps modded idm
powerstroke02 is offline
post #2 of 39 (permalink) Old 12-22-2009, 12:20 AM
Layson's Avatar
Re: turbo ?in
what sticks?
Layson is offline
post #3 of 39 (permalink) Old 12-22-2009, 12:38 AM Thread Starter
Re: turbo ?in
di's mini me(stage 3)
2002 psd,4x4 ECSB
DP-TUNED
4" lift 35" tires
3.73 gears
Full 4" exhaust
K&N fipk
FASS system
cutsom built trans
di's up pipes
6.0 trans-cooler
ccv moved
swamps modded idm
post #4 of 39 (permalink) Old 12-22-2009, 12:40 PM
The Fireman
big_stroker's Avatar
Re: turbo ?in
You better go with a 38r. I don't think a stock turbo will last long with mini me's even with the other parts.
big_stroker is offline
post #5 of 39 (permalink) Old 12-23-2009, 01:52 AM Thread Starter
Re: turbo ?in
ok is there any other good opitions out there?
2002 psd,4x4 ECSB
DP-TUNED
4" lift 35" tires
3.73 gears
Full 4" exhaust
K&N fipk
FASS system
cutsom built trans
di's up pipes
6.0 trans-cooler
ccv moved
swamps modded idm
post #6 of 39 (permalink) Old 12-23-2009, 01:16 PM
The Fireman
Re: turbo ?in
I just noticed you have an 02 with PMR's and DP tuning. And you are getting Hybrids.
I don't think the turbo is what you should be worrying about. Good luck
post #7 of 39 (permalink) Old 12-23-2009, 10:53 PM Thread Starter
Re: turbo ?in
yea havin jody tune it for that
2002 psd,4x4 ECSB
DP-TUNED
4" lift 35" tires
3.73 gears
Full 4" exhaust
K&N fipk
FASS system
cutsom built trans
di's up pipes
6.0 trans-cooler
ccv moved
swamps modded idm
post #8 of 39 (permalink) Old 12-24-2009, 01:17 AM
Myles_S's Avatar
Re: turbo ?in
Might wanna do a little readin bud
99.5 F250, 4x4, Lariat, CC/SB, 4r100 Gauges, Intake, Exhaust, Lots of black/smoked parts
Originally Posted by Coltaine View Post
I ride solo, being able to converse with yourself is a skill that creeps up on you.
Black Ops 360
Gamertag; See Ya LATER 73
Myles_S is offline
post #9 of 39 (permalink) Old 12-24-2009, 01:25 AM Thread Starter
Re: turbo ?in
Why do u say that? Jody can detune it right?
2002 psd,4x4 ECSB
DP-TUNED
4" lift 35" tires
3.73 gears
Full 4" exhaust
K&N fipk
FASS system
cutsom built trans
di's up pipes
6.0 trans-cooler
ccv moved
swamps modded idm
post #10 of 39 (permalink) Old 12-24-2009, 01:31 AM
Myles_S's Avatar
Re: turbo ?in
I've heard of tooooo many carnage stories
Others run the piss out of there truck and have no issues. I wont take my chances, Matts handling my tuning needs
Black Ops 360
Last edited by bigrpowr; 12-24-2009 at 02:03 AM. Reason: please no vendor bashing.
Myles_S is offline
