Adrenalin broke my fuel tank sender - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 12-21-2009, 04:08 PM Thread Starter
CGMKCM's Avatar
While using AE speed Tracer data logging my new pump, I did an acceleration run (boosted launch).
My fuel level was 2/3, after the run the needle climbed to Full + and is now stuck there.
One of two things happened, either the Adrenalin makes so much power that the G force took out my fuel sender or the Adrenalin can make fuel. Either way I am thrilled with the pump, it works well.
On a serious note has anyone successfully unstuck a sender without dropping the tank? Any ideas are welcome.
[SIGPIC][/SIGPIC]
2001 F-550 4X4 Lariat
BTS Tranny
PHP Phoenix chip
H2E Turbo With WW II
Adrenalin
Banks Intercooler and exhaust
In tank and pre-pump mods
Numerous minor Mods
Other Diesels
08 GL 320 CDI
02 VW Golf TDI
3054 Kioti Tractor
Kubota ZD 323
CGMKCM is offline
post #2 of 19 (permalink) Old 12-21-2009, 04:10 PM
Re: Adrenalin broke my fuel tank sender
i believe i read on a thread with a stuck fuel sender that some hit the tank with a rubber mallet
02 f250
countryboyrob is offline
post #3 of 19 (permalink) Old 12-21-2009, 04:20 PM
mnstroker's Avatar
Check the plug above the tank. The connection could have came apart?
Back to stock for now.
Originally Posted by 1800joedaddy View Post
It's one thing to get cornholed... its another to pay for the cornholing!
mnstroker is offline
post #4 of 19 (permalink) Old 12-21-2009, 08:16 PM
All done now
Arisley's Avatar
Or a hunk of 2X4.
Arisley is offline
post #5 of 19 (permalink) Old 12-21-2009, 08:21 PM
rebelchevy02's Avatar
Mine got stuck at full once. For a while I thought I was getting amazing mileage. Then a couple days later, it unstuck itself.
DRW and tow fast parts.......
rebelchevy02 is offline
post #6 of 19 (permalink) Old 12-21-2009, 08:41 PM
Turbo99's Avatar
when mine stuck on my 99' I just filled it up a few times and after about 3 tanks it was back to normal
_____________________________________________
Jeremy
08'F250 CCSB 4x4 ALL White except whats Black!!
10' Camaro 2SS LS3 All White except whats Black!! Supercharged 682 RWHP 10.80 @ 131mph
Turbo99 is offline
post #7 of 19 (permalink) Old 12-21-2009, 09:24 PM
Moved in
sagebel's Avatar
Large pot holes did it for me.
2011 F250 CC 4x4 Sterling Gray Metallic
2010 Cannondale Quick 4 (pedal powered commuter)
sagebel is offline
post #8 of 19 (permalink) Old 12-21-2009, 09:25 PM
A Ghost these days...
farm boy's Avatar
I did a boosted launch at the track and the same thing happened. Except I rode around for a few months with it like that. It was stuck good. I had to drop the tank to un-stick it. The rubber mallet didn't work.
2002 F-250 4X4 Flatbed
~Cryo'd Forged Rods ~Comp 910's ~DI Push Rods ~ARP Studs ~IH Up-pipes ~GTP38R/1.15 ~238/80's ~Fuelab ~Built Auto ~Matt's Tunes ~Water Inj. ~Gooseneck Brand Flatbed
Rockin' Out with some help from: Alpine / Rockford Fosgate / Memphis / Infinity
farm boy is offline
post #9 of 19 (permalink) Old 12-21-2009, 11:26 PM
JuststrokeIT's Avatar
Send a message via MSN to JuststrokeIT
I did a boost launch once and mine got stuck straight up dont ask me how because i dont remember fliping over or anything like that but i had to pull the bed and unstick mine pulling the tanks easier but i bedlined and cleaned up my frame while i was at it
early 99 F350 Supercab longbed 4x4, Diprical gauges,GTP38R, Swamps competion fuel system with bowl delete,custom intake, 4in downpipe to 6in stacks, 200/30% hybrids from swamps, tuned by swamps, head studs.main studs, WOP cryo forged rods, ceramic coated pistons,Adrenalin HPOP,DI cam. Train horns, Ranchand front bumper DMI rear, Kumho kl71
JuststrokeIT is offline
post #10 of 19 (permalink) Old 12-22-2009, 03:04 AM
Village Idiot
southmike's Avatar
hope it is not really cold where you are when you go beating on a plastic tank...lol
southmike is offline
