38r install - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 31 (permalink) Old 12-20-2009, 08:42 PM Thread Starter
<--before leveler & block
stroker2's Avatar
38r install
Hi i have a gtp38r coming from diesel site and brass donuts coming from Beans diesel. They both should be here this coming weekend. I was wondering if any of you had any tips for the install. how long will it take? I have started sparaying all the bolts and nuts i can with pb blaster a couple days ago. Thanks in advance
2000 7.3 F-250 4x4 CC/SB Lariat 6-speed, 2.5" leveler and F350 block, Swamps 200/30% injectors, Swamps tunes, GTP-38R, Valair: kevlar/ceramic clutch, 4inch exhaust, AFE stage 2,
DFA-regulated return, pre-pump mods, Isspro boost and pyro, scan gauge, ~420hp and 836tq
stroker2 is offline
post #2 of 31 (permalink) Old 12-20-2009, 08:58 PM
bobvillaoftn's Avatar
Re: 38r install
no offense but with the EBPV brake id watch the back pressure on the turbo, yes it works but it can also do quite some harm, ive heard of a couple biting the dust because of it. i dont know about the turbo since im an OBS but it should be relatively simple, IIRC its a drop in an i believe turbos can be replaced in 3 hours or so if ya know what your doing. im sure someone will chime in for you though.
05 f350 CCLB 4x4 delete and sct x4 thanks to innovative
Originally Posted by RedSmokey View Post
Sh*t in a box (litterally) and write "Will give you 200+ hp, just add to your fuel" on the box and give it to him. Then ask him if he still believe's everything thats written on a box...
Originally Posted by bruce51d View Post
if you can blow up a 7.3 just imagaine what you would do to a 6.0
bobvillaoftn is offline
post #3 of 31 (permalink) Old 12-20-2009, 09:19 PM
fishstick's Avatar
Re: 38r install
think it took me about 5hours the ex band clamp is the bad part and its not that bad
fishstick is offline
post #4 of 31 (permalink) Old 12-20-2009, 09:20 PM Thread Starter
stroker2's Avatar
Re: 38r install
Yeah i comletely agree with ya about the EBPV brake. I bought the truck with that mod installed an i only use it for warm ups. I never use it for branking of anything. It is only used at 1100 rpm or less. In fact i think thats part of the reason my donut gaskets are leaking badly. Hopefully my brass ones fix that! Im thinking the install should be pretty straight forward also. The only problem i see now are stubborn bolts
stroker2 is offline
post #5 of 31 (permalink) Old 12-20-2009, 09:23 PM
Deputydog's Avatar
Re: 38r install
Installation instructions
Deputydog is offline
post #6 of 31 (permalink) Old 12-20-2009, 09:31 PM Thread Starter
stroker2's Avatar
Re: 38r install
Those instructions seem pretty straight forward thanks! Any tricks on replacing the donut gaskets other than soaking the bolts in pb blaster?
stroker2 is offline
post #7 of 31 (permalink) Old 12-20-2009, 09:34 PM
Deputydog's Avatar
Re: 38r install
I like using a little grease or vaseline on the o-rings to help hold them in place while mounting the turbo and pedistal.
post #8 of 31 (permalink) Old 12-20-2009, 10:07 PM
JuststrokeIT's Avatar
Send a message via MSN to JuststrokeIT
Re: 38r install
be prepared to buy a irwin or comperatble rounded bolt head tool itll get you outta a jam if you get too carried away and anti sieze the piss outta everything when you reinstall it.
early 99 F350 Supercab longbed 4x4, Diprical gauges,GTP38R, Swamps competion fuel system with bowl delete,custom intake, 4in downpipe to 6in stacks, 200/30% hybrids from swamps, tuned by swamps, head studs.main studs, WOP cryo forged rods, ceramic coated pistons,Adrenalin HPOP,DI cam. Train horns, Ranchand front bumper DMI rear, Kumho kl71
JuststrokeIT is offline
post #9 of 31 (permalink) Old 12-21-2009, 12:16 AM Thread Starter
stroker2's Avatar
Re: 38r install
ok thanks for all the help! hopefully i dont run into to much trouble!
stroker2 is offline
post #10 of 31 (permalink) Old 12-21-2009, 03:31 AM
Canadian Stroker
doubledoor's Avatar
Re: 38r install
When I did my bellowed up pipes the only problem I had was getting the V-clamp off the up pipe collector. I ended up pulling out the collector with the turbo. I didn't use any oil on the bolts and they all came out fine. I was very surprised. Another spot that might give you problems is the bolts in the manifolds that hold the up-pipes. They are bolts so if you work them back and forth they will come out. It's not that bad of a job. Just a pain leaning over the truck.
2002 XLT CC LB 6speed SRW
4"mbrp turbo back
S&B Intake
autometer NV boost,pyro,water temp and oil pressure
WW2,BRV
DP tunes - QI,60E,80E,40T,60T,100,120.
EBPV delete sensor.
blank pedestal and EBPV housing
ATS turbo housing
DI up-pipes.
2007 headlights,2008 taillights,2010 tailgate
17"Atx ledge with Dick Cepek Extreme Country
doubledoor is offline
