mechanical fuel pump - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 12-20-2009, 11:37 AM Thread Starter
mouse4x4's Avatar
I just got a psd and it has a mess of miles on it idling a bit rough and so on. It is more or less going be a economical toy. I am going to change it over to electric fuel pump but unsure what the removal of the oem pump brings. Besides the obvious is there any adapter that drives the pump from the cam that needs removal or do I just pull the pump and that's it.
96 350 LB CC 4x4, 5 speed, 4 inch all spring lift, 35 mt, 18 inch classic 2, beans stage 1 injectors, beans custom tunes, 3in down pipe 4in mbrp exhaust, cold air intake, idm modd 220,000
05 QC 3500 SB Cummins, 5 inch moto blue, afe intake, daddy built trans, magtec DD, 4.10 gears, edge juice with tude, 120,000
mouse4x4 is offline
post #2 of 5 (permalink) Old 12-20-2009, 11:40 AM
Sponsor
Re: mechanical fuel pump
just remove the pump and get a freeze plug to put back in the hole. Of course you will have to redo the rest of the fuel system as well, but I figure you already are aware of that. Nothing special in there.
UNLIMITED_DIESEL is offline
post #3 of 5 (permalink) Old 12-20-2009, 11:47 AM Thread Starter
mouse4x4's Avatar
What is the follower I heard about dropping if u r not careful pulling the pump out. Thanks for the fast response. What do u do with the wiring on the fuel bowl when u remove it. If there is any.
mouse4x4 is offline
post #4 of 5 (permalink) Old 12-20-2009, 11:51 AM
dinnerbooter treasurer
genuineford's Avatar
It is a 7/8's freeze plug that you need. The wiring you can remove or tie up. I believe there is just the fuel bowl heater and the water in fuel light, neither of these have to be hooked up for the vehicle to function properly.
93 F350 Gasser
03 F250 6.0
dinnerbooter #3
genuineford is offline
post #5 of 5 (permalink) Old 12-20-2009, 12:05 PM Thread Starter
mouse4x4's Avatar
Thanks for the quick response
mouse4x4 is offline
