More fuel...More Injector Questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 12-20-2009, 02:45 AM Thread Starter
Myles_S's Avatar
Late 99, Daily Driver is its main use, looking for 400+ HP after a turbo upgrade (GTP38r) however the sticks will be ran on the stock turbo untill i can afford the upgrade.
Matt will handle the tuning so im thinking 238cc hybrids w/ 100% nozzles from Nate. What is your guys take? I need something that can be de-tuned to run safely on the stock turbo until i upgrade and then turned up for 400+ once i get the 38r in.
Will i NEED to upgrade my fuel system to run these? Im still very open on my choice of sticks so school me fellas
Thanks
99.5 F250, 4x4, Lariat, CC/SB, 4r100 Gauges, Intake, Exhaust, Lots of black/smoked parts
Originally Posted by Coltaine View Post
I ride solo, being able to converse with yourself is a skill that creeps up on you.
Black Ops 360
Gamertag; See Ya LATER 73
Myles_S is offline
post #2 of 18 (permalink) Old 12-20-2009, 03:00 AM
Sofa King Cool
BMac's Avatar
Send a message via AIM to BMac Send a message via MSN to BMac Send a message via Skype™ to BMac
Re: More fuel...More Injector Questions
you can do the standard 238's with 80% nozzles, it'll be more then enough for your goals
People Fly Airplanes, Pilot's Fly Helicopters
2002 F350 Extended Cab Shortbed
1977 Early Bronco
BMac is offline
post #3 of 18 (permalink) Old 12-20-2009, 04:02 AM Thread Starter
Myles_S's Avatar
are you saying the 100% nozzles will be overkill? I just dont want to catch the "i want more" that were all to familiar with any sooner than i have too. Know what i mean?
Black Ops 360
Myles_S is offline
post #4 of 18 (permalink) Old 12-20-2009, 04:04 AM Thread Starter
Myles_S's Avatar
will i NEED any sort of fuel upgrades with a combo like this? I know i wont lose anything from upgrading but will i lose something from NOT upgrading?
Truck just got a new pump installed back in the summertime...
Black Ops 360
Myles_S is offline
post #5 of 18 (permalink) Old 12-20-2009, 04:19 AM
PSA
mclean's Avatar
subscribing...sounds like the exact same thing im wanting to do
mclean is offline
post #6 of 18 (permalink) Old 12-20-2009, 04:34 AM
Sofa King Cool
BMac's Avatar
depends how much more you want, 100% won't be overkill, but with the 238's 80% you should be closer to the 500 mark with the 38r, reg return would be a good idea as well
1977 Early Bronco
BMac is offline
post #7 of 18 (permalink) Old 12-20-2009, 04:48 AM Thread Starter
Myles_S's Avatar
Dayumm. Close to 500 with just 80%? I was gonna be happy with anything over 400. Guess the 80% will suffice. Should I be looking into any engine mods other than valve springs? What boost #'s can I expect with this combo on the 38r? Mid 30's low 40's?
Black Ops 360
Myles_S is offline
post #8 of 18 (permalink) Old 12-20-2009, 05:06 AM
OverFuelingForYourPlesure
pontiacross's Avatar
do springs, push tubes and head studs while your in there.
Ross
2.6 modified street pulling truck "The Lone Stroke
-1996 f350, stock bottom end! swamps 400/400% injectors, swamps BFH turbo, swamps IDM, Swamps tunes, BTS oil, springs, studs, tubes, fuel system, water to air cooler, and much more...
-97 f350 4x4 CCLB tow rig
pontiacross is offline
post #9 of 18 (permalink) Old 12-20-2009, 07:35 AM
Layson's Avatar
Stock fuel system will get you to 400...
Layson is offline
post #10 of 18 (permalink) Old 12-20-2009, 09:25 AM
aggie's Avatar
if youre going to be running a stock turbo, you can get away with the stock fuel system. Id just have a way of watching your fuel pressure in the cab incase you start to drop, you dont want to damange the injectors.
i think 238s with 80% nozzles would be plenty fine for your application. Theyre capable of 500 horse and will have a little less smoke and a slightly smoother idle than the 100s.
boost will depend what housing you put on the 38r. the 1.0 housing seems to be 38-42, and the 1.15 housin ususly does 35-40.
some studs, valvesprings, and pushrods would be a good assortment of parts to put on the motor to make it durable for your horsepower goals.
[SIGPIC][/SIGPIC]
aggie is offline
