oil return on Hypermax pedistal - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 12-19-2009, 07:44 AM Thread Starter
What is the best thing to use for a return line? I am changing around a Hypermax pedestal and collector that I have and am just going to bend some stainless tubing for an oil feed line but am unsure of what to use for a return. Does the line just push into the return port or can I thread something and put a fitting on it? I will be mounting an S475 with a T4 housing.
bigjake0524 is offline
post #2 of 5 (permalink) Old 12-20-2009, 07:01 PM
racehauler's Avatar
Re: oil return on Hypermax pedistal
You can put a fitting of some sort into the pedestal or just plug it and run the drain down to the hole with a soft plug in it in the middle of the valley. This hole was originally used for the mechanical fuel pump that was on the OBS trucks.
Personally I like the Hypermax kit where it has the solid tube with a flex section (pita to make it flex but it can be done) and it just slips through the pedistal with the o-ring seal. As long as you have the tube going straight down through the pedestal it will not leak.
You could just make it a solid tube on your setup. The only reason the Hypermax one has a flex section is to allow a little adjustment tweaking by the installer.
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
post #3 of 5 (permalink) Old 12-21-2009, 12:14 AM Thread Starter
Thanks. I'll get it all mocked up and then figure out a return. Or just order a return line from Hypermax.
post #4 of 5 (permalink) Old 12-21-2009, 05:52 PM
Does this hole exist on the SD engines?
09 F450 6.4 PSD 5r110 4x4, H&S XRT Pro, Edge CTS Insight
schmity is offline
post #5 of 5 (permalink) Old 12-21-2009, 05:57 PM
Don't EFN worry about it
Aljay's Avatar
Yes its plugged from the factory . With a freeze plug.
Tuned by T Wildman
Aljay is offline
