truck breaks up - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 12-19-2009, 02:41 AM Thread Starter
truck breaks up
i have a 99 and when i floor it from a dead stop the truck sound like it is breaking up or missing it does it in all of my dp setting 120 and 140 not so much in the 80econ. i have an aeromotive pump and complete fuel system with reg return so i don't think it is running out of fuel. with low hpo cause this symptom?. if you roll into it nice and steady i seams fine any ideas. Thanks Brad
99oilburner is offline
post #2 of 13 (permalink) Old 12-19-2009, 02:45 AM
<< wasted fuel >>
haulin99sdp's Avatar
Re: truck breaks up
what are you running for exghust?
reason i ask is cause i exprienced this same problem with the 5in and swamps tunes.
it wasent really a loss of power but you kno its 8 cylinders. never felt the need to invistagate cause shortly after i found two bent push rod's.
haulin99sdp is offline
post #3 of 13 (permalink) Old 12-19-2009, 03:13 AM Thread Starter
Re: truck breaks up
i don't have much on for exhaust i had stacks and took them off and it just dumps under the truck now didn't get any exhaust put back on yet.
post #4 of 13 (permalink) Old 12-19-2009, 06:49 AM
<< wasted fuel >>
Re: truck breaks up
check engine light?
post #5 of 13 (permalink) Old 12-19-2009, 04:44 PM Thread Starter
Re: truck breaks up
no check engine light
post #6 of 13 (permalink) Old 12-19-2009, 05:00 PM
Myles_S's Avatar
Re: truck breaks up
whens the last time you changed the fuel filter
99.5 F250, 4x4, Lariat, CC/SB, 4r100 Gauges, Intake, Exhaust, Lots of black/smoked parts
Originally Posted by Coltaine View Post
I ride solo, being able to converse with yourself is a skill that creeps up on you.
Black Ops 360
Gamertag; See Ya LATER 73
Myles_S is offline
post #7 of 13 (permalink) Old 12-19-2009, 05:53 PM Thread Starter
Re: truck breaks up
i only put 3000 miles on a year but it was changed regular it may have 1500 miles on it. the last two times the filter was black can injector orings cause my problem
post #8 of 13 (permalink) Old 12-19-2009, 08:04 PM
godofdew11's Avatar
Send a message via AIM to godofdew11
Re: truck breaks up
meter your TPS, might have dead spots. or be intermitant. my dads 99 has been through 2 or 3 of them.
-Don
'03 F-350 SC LB, 4x4 7.3, loaded, 3.5" DP to 4" Ex, tymar intake, 38r, strobes and LEDs galore. windshield mount 3 gaude pod,Gearhead toonz,BTS VB, 2.5" leveing kit. Toyo 315s. Last of the 7.3's
godofdew11 is offline
post #9 of 13 (permalink) Old 12-19-2009, 08:49 PM
What else?
smokyred's Avatar
Re: truck breaks up
Verify you have fuel pressure, it will do exactly as you describe when you don't have any.
Dave
smokyred is offline
post #10 of 13 (permalink) Old 12-21-2009, 02:27 AM
Village Idiot
southmike's Avatar
Re: truck breaks up
any updates?
southmike is offline
