Normal pressure?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 24 (permalink) Old 12-18-2009, 06:22 AM Thread Starter
Normal pressure??
I am a little concerned as to why my boost pressures are higher than what others are running with a stock turbo. I got an AIS intake and 4 in exhaust with a BTS trans and Cale's tunes. At 65 I am running about 600 egt and 5-6 psi boost which is higher than what I was running a few months ago. Is this normal or should I be looking for a bearing or a dragging brake?
pilot4life is offline
post #2 of 24 (permalink) Old 12-18-2009, 11:54 AM
TARM's Avatar
Re: Normal pressure??
If it was a dragging brake I woudl think you should notice a good hit to your mileage. Everything about the same there? Did you change anything between then and now? I assume you had the listed upgrades before as well.
TARM is offline
post #3 of 24 (permalink) Old 12-18-2009, 12:00 PM
PSN Mega Miler
crowz's Avatar
The boost sounds a little high maybe but the egts look good for 65mph.
Depends on your gearing. Mine does a few pounds somewhere around there speed wise.
2002 F250 SuperDuty Lariat PSD 7.3 Crew Cab 4x4 302,000+ miles.
, Valvoline Extreme Blue 5w40 Synthetic,
, Clifford Matrix 50.5x Alarm
, P3 Brake Controller, Swamps Injectors, PHP Tunes
crowz is offline
post #4 of 24 (permalink) Old 12-18-2009, 07:25 PM Thread Starter
Back before I had the transmission done I was averaging 14-15 city driving during the summer months. After I had the trans done I had Cale load some different tunes and I continued my move with a 17,000 trailer. With the winter diesel I have dropped down to 10-11. My EGT as far as I know have not increased but my boost numbers are about 3 psi higher than usual. Cold weather maybe? Maybe my wife is right and I am too "sensitive".
post #5 of 24 (permalink) Old 12-19-2009, 06:21 AM
TARM's Avatar
Is that 10-11 towing I hope.
TARM is offline
post #6 of 24 (permalink) Old 12-20-2009, 04:02 AM Thread Starter
It was when I was towing...now it is there all the time....thats what I don't get.
post #7 of 24 (permalink) Old 12-20-2009, 04:10 AM
Myles_S's Avatar
If anything the new tranny should help with mileage... whats your DD tune and do you lay heavy on the smoke pedal?
99.5 F250, 4x4, Lariat, CC/SB, 4r100 Gauges, Intake, Exhaust, Lots of black/smoked parts
Originally Posted by Coltaine View Post
I ride solo, being able to converse with yourself is a skill that creeps up on you.
Black Ops 360
Gamertag; See Ya LATER 73
Myles_S is offline
post #8 of 24 (permalink) Old 12-20-2009, 04:17 AM Thread Starter
I run an 80hp econo tune from Cale. I don't floor it all the time 2000 is about what it runs when accelerating and highway driving.
post #9 of 24 (permalink) Old 12-20-2009, 05:04 AM
Super Hauler!
Super_Hauler's Avatar
2000?
Super_Hauler is offline
post #10 of 24 (permalink) Old 12-20-2009, 06:26 AM
stroked99_1/2's Avatar
What gears do you have?
2000 sounds a little high for 60-65mph unless you have 4.10's or something like that
stroked99_1/2 is offline
