Should I Turbomaster - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 12-18-2009, 02:01 AM Thread Starter
Just wanted to get some opinions on whether you guys thinks I would benefit from a Turbomaster wastegate controller? If so how?
02 7.3l ,4' turbo back exhaust,intake,aih delete,05 front end conversion,PHP FU chip w/stock,whisper,80DD,100HP,75HP fuel sipper,smoke show,ITP hx line,wicked wheel
brc51m is offline
post #2 of 10 (permalink) Old 12-18-2009, 02:17 AM
greenbeast's Avatar
Re: Should I Turbomaster
Save your money and up-grade the exhaust housing to non wastegated. Much better set up than the stocker and no need for a wastegate. Beans Diesel Performance - 99-03 Power Stroke 1.0 A/R NON-wastegated Turbine Housing w/ adapter (Powered by CubeCart)
greenbeast is offline
post #3 of 10 (permalink) Old 12-18-2009, 03:09 AM
owner/president
dixieland-diesels's Avatar
Send a message via MSN to dixieland-diesels
Do you have a boost gauge?
03 lariat cc,4x4 7.3,DP-F5,36''MT,8"lift w/trac.bars,4"Silverline ss.exh,AFE II,Optimas,ATS housing,WW,Turbomaster,6.0 IC & tranny cooler,BTS,ISSPRO gauges,HPX,ITP RR,BRV+,Powerslots,WARN prem-hubs,coolant filter,ccv mod,08 mirrors,ARP's,mod.fuel & inj's.,Crower rods,AIH delete,AMSOIL fluids. ~waitn on the 38R~
dixieland-diesels is offline
post #4 of 10 (permalink) Old 12-18-2009, 04:55 AM Thread Starter
yeah i have boost gauge and max boost WOT is about 20
brc51m is offline
post #5 of 10 (permalink) Old 12-18-2009, 12:26 PM
owner/president
but if you didn't want to go that way right now,you could unplug the red line(tube) or you could shorten the wg's rod inorder to make the spring stiffer or since you have a boost guage you could remove the wg and wire the gate shut.I like the TurboMaster because its easy to adjust.
post #6 of 10 (permalink) Old 12-18-2009, 02:09 PM Thread Starter
How involved is the install on beans product?
brc51m is offline
post #7 of 10 (permalink) Old 12-18-2009, 02:15 PM
greenbeast's Avatar
Pull the turbo off, install the housing and adapter put turbo back on. Its not that bad aof a job realy.
post #8 of 10 (permalink) Old 12-18-2009, 02:27 PM
Work in progress
opieg01's Avatar
I like my turbomaster but if I had to do it again I would pull the turbo to put it on because of the e clip in back on the waste gate. It can be done in the truck with a mirror, alot of cussin and patients. My suggestion is pull the turbo and do what the guys about said
2001 F-250 4X4 LARIAT Crew Cab,7.3, ZF6
GTX-4294r, Swamps 300/200%
couple other bolt ons
opieg01 is offline
post #9 of 10 (permalink) Old 12-18-2009, 05:06 PM
Well Hung Member
stroked's Avatar
clamp that #### shut, dont waste your time or money on an aftermarket actuator,... or as said before take that money and buy a non wastegated housing
Donnie
2001- just the basics
2005 6.0 Studded, Deleted, 58v Swamps/PHP tuned Ficm, SOLD
99.5 hybrids, termy modded 17*, GT4294 TOTALED
stroked is offline
post #10 of 10 (permalink) Old 12-19-2009, 10:33 AM
I noticed a definite improvement with the turbomaster, even with stock tunes. Install can be hell if all does not go right. I had a defective, possibly, bent turbomaster and I could not get it to work right, even with the turbo out of the truck. It would have been a total nightmare in the truck. But, Bob at Dieselsite sent me a new one and then the install was a joke, out of the truck.
2002 f-350 PSD, 4x4, cc short bed, 6spd, ccv mod, airdog, AIS filter, isspro ev and scangauges, detroit TT, ITP boost annihalator, ITP RR, bellowed up-pipes, ats housing, turbomaster, 3.5 dp magnaflow, very happy with ultra smooth and linear PHP 50t, 80DD and "whisper" tunes.
clydesdale is offline
