38r & high egt's - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 12-17-2009, 06:28 PM Thread Starter
JTA
Cool 38r & high egt's
OK I have a 2002 with intake and exh mods with a TSchip and recently installed a 38r turbo. I was expecting lowere egt's but they are the same as the old turbo? If from a dead stop I go all out I have to shut it down at 55mph because egt's are at 1250, is this normal? I have checked the up pipes and intercooler for leaks but didnt find any. The turbo has a 1.0 exh housing should I go to a 1.15? I also left the ebpv inslalled. Or do I have another problem somewhere? My boost pressures at 70mph are 1-2psi and at full throttle are 28psi. Any help or sugestions are greatly appreciated.
JTA is offline
post #2 of 21 (permalink) Old 12-17-2009, 06:35 PM
Ticking time bomb
Re: 38r & high egt's
Get the 1.15 but also get some good custom tunes a 4 inch tb exhaust will also help if you don't already have one
groomzybanshe is offline
post #3 of 21 (permalink) Old 12-17-2009, 06:46 PM
Work in progress
opieg01's Avatar
Somethings leaking I bet. Check your up pipes, boots and manifolds. I think dieselsite sells a kit to check for leakage in the intercooler system, or make your own for cheap. make sure your ebpv is open all the way and isnt partially closed.
With stock sticks 28 seems a little low.
I wouldnt go to a 1.15 unless you have upgradded your sticks to stage 2 or above
2001 F-250 4X4 LARIAT Crew Cab,7.3, ZF6
GTX-4294r, Swamps 300/200%
couple other bolt ons
opieg01 is offline
post #4 of 21 (permalink) Old 12-17-2009, 06:48 PM
The Fireman
big_stroker's Avatar
The 1.15 isnt going to do you any good. I have the 1.00 housing on 38r on my truck and dont have any issues and I have big injectors.
Get some better tuning. With Matt's tunes from Gearhead on the daily driver setting i cant get it to over 1150 degrees.
Get him to reburn your TS Chip you will be MUCH happier
big_stroker is offline
post #5 of 21 (permalink) Old 12-17-2009, 06:49 PM
The Fireman
28 psi with stock sticks is not low at all. Its about right.
post #6 of 21 (permalink) Old 12-17-2009, 08:10 PM Thread Starter
JTA
ya I already have a 4''dp, and have checked everywhere for leaks excpt the compressor housing. will check the ebpv and do some checking on a custome burned chip. Also when I bought the turbo it was used and it didnt come with a wastegate acctuator so I used the one off the stock turbo is that something I would need to change? Thanks everyone for the replys
JTA is offline
post #7 of 21 (permalink) Old 12-17-2009, 08:21 PM
<-- it's like that
28 psi on stock sticks and a TS chip is about right.
However, with a 38R and stock sticks, you don't need the wastegate to open up. Take your actuator and tighten it as far down as it will go. You can also wire it shut by wrapping some wire around that wastegate arm where it attaches to the actuator, and snugging it down to something to keep it from opening.
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's.
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the
Pocket is offline
post #8 of 21 (permalink) Old 12-17-2009, 09:01 PM
Phiber Optik's Avatar
check your spider boots... I had to replace mine when I installed my 38R they were so oil soaked I couldn't get a good seal on the intake plenum
2008 F-350 CC SB Lariat, 4wd, 20x12, 35x14.5, 4" lift w/ Bags, 4" Exhaust, IC Pipe, Elbow, S&B Intake, EGR Delete, Gearhead Tunes, Hellwig Sways, Recon Ltng
2000 Corvette - JT Trim Vortech
2007 HusaberG FS650
2008 RZR - Z1 Turbo
Phiber Optik is offline
post #9 of 21 (permalink) Old 12-17-2009, 09:34 PM
Well Hung Member
stroked's Avatar
also make sure that you installed that o ring on the front of the compressor housing,... been there
Donnie
2001- just the basics
2005 6.0 Studded, Deleted, 58v Swamps/PHP tuned Ficm, SOLD
99.5 hybrids, termy modded 17*, GT4294 TOTALED
stroked is offline
post #10 of 21 (permalink) Old 12-17-2009, 10:35 PM
Haulin' Iron
superih's Avatar
Except I can hit 34 psi with mine and stock sticks.
'99 F-350 CC SB Lariat 4x4 Auto -DI chip-GTP38R-BPV delete-Zoodad-Suncoast tugger trans-6.0 trans cooler-Powerstop brakes-CCV-Gauges-Exhaust-AIS Intake-Kenwood sounds-
-Traveling the Earth 300 ft at a time-
superih is offline
