Fuel System - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 12-16-2009, 05:22 AM Thread Starter
Fuel System
I'm going to be running a Fuelab pump that will be fed by a 5/8's line and then neck down to 3/8's after the pump. Is it OK to run the factory return line to the tank or does it need to be upgraded as well? I will be adding a 5/8's pick up as well.
bigjake0524 is offline
post #2 of 3 (permalink) Old 12-16-2009, 05:37 AM
Powerstroke Racer's Avatar
Re: Fuel System
Stock return line is fine.
Powerstroke Racer is offline
post #3 of 3 (permalink) Old 12-16-2009, 06:07 AM Thread Starter
Re: Fuel System
Thank you very much. Saves a little bit of work.
