Chip ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 12-15-2009, 03:11 AM Thread Starter
JHill's Avatar
Chip ?
60 Tow gold superchip from a E99 7.3 6 speed,
can I use it on on a '02 7.3 6 speed ? or can anybody here reburn for the pcm code?
I see the AIH bieng an Issue (not really a big deal)only because the early trucks didn't have one, my new pcm for the hybrids always has a soft code for the AIH but i dont have one similar just reversed in this case.
pin out's on the harness different?
Bieng a PMR motor and a work truck it would be nice to be able to use my left overs, have a AIS and a 2 pod pillar mount from the E99
E '99 F-350 CC LB, ZF6, IDP -T4i Mount, Comp. Fuel System, , Reg. Return, Comp Valve springs, ARP's, DI P- Rods, Adrenaline HPOP, Isspro's, Detroit Tru Trac
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #2 of 10 (permalink) Old 12-15-2009, 06:04 AM Thread Starter
JHill's Avatar
Re: Chip ?
Can one of the Moderators move this to the Tech. Forum
Thanks
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #3 of 10 (permalink) Old 12-15-2009, 06:19 AM
Re: Chip ?
bigjake0524 is offline
post #4 of 10 (permalink) Old 12-15-2009, 06:37 AM Thread Starter
JHill's Avatar
Re: Chip ?
found my answer
I still have all my old Superchips burners and if you want I can replace/retune the program with the latest and greatest stuff available. Give me a shout if you're interested and we can set you up.
As Vengance said, MLE0 and MLE1 are nearly identical. Even for a 1 Bank Superchips, they interchange just fine. The same with TDE0 and TDE1.
Take care.
__________________
Bill Cohron - (678) 963-9913
Proud SPONSOR of Powerstroke Nation
http://www.powerhungryperformance.com - The Original in "Custom" Ford Tuning
http://www.dygytalradio.com - Some "TUNES" for your ears...
MySpace - DJ dYgYtAl - 41 - Male - Winder, Georgia - myspace.com/djdygytal
- A little more about me...
FOREVER
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #5 of 10 (permalink) Old 12-15-2009, 06:42 AM Thread Starter
JHill's Avatar
Re: Chip ?
I think I found my own answer
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #6 of 10 (permalink) Old 12-15-2009, 04:52 PM
Village Idiot
southmike's Avatar
Re: Chip ?
what do you mean soft code... CEL?
the reason I ask is I went from my early 99 xle to a pmt pcm
i see no codes no lights that I have found or the NC obd2 emissions scan.
but i see where AE and the scan gauge can get hung up on tests by not finding the aih.
southmike is offline
post #7 of 10 (permalink) Old 12-15-2009, 05:38 PM
dinnerbooter treasurer
genuineford's Avatar
Re: Chip ?
I may be wrong but I think a soft code is one that does not set a CEL but will be stored in memory.
93 F350 Gasser
03 F250 6.0
dinnerbooter #3
genuineford is offline
post #8 of 10 (permalink) Old 12-15-2009, 05:41 PM
theSLEEPER's Avatar
Re: Chip ?
It sets a CEL, but it goes off.
theSLEEPER is offline
post #9 of 10 (permalink) Old 12-15-2009, 06:56 PM
ELKHUNTER's Avatar
Re: Chip ?
No CEL just stored codes.
Josh
2000 F350 205,000
STAGE II SPLITS 100%
STEALTH SRP1
TYRANT TUNES
38R TURBO
BTS VALVE BODY
WALBRO 392
SCANGAUGE
ISSPRO
MORE STUFF
ELKHUNTER is offline
post #10 of 10 (permalink) Old 12-16-2009, 02:36 AM Thread Starter
JHill's Avatar
Re: Chip ?
what Elkhunter and Geniuneford said ,every time I have scaned my truck for codes it always has 2 for the AIH- no CEL.
BTW -Bill confirmed no go without a reburn
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
