HP to run alternator - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 12-14-2009, 01:45 AM Thread Starter
Powerstroke Racer's Avatar
Any of you smart electrical guys know how much power our alternators use at full charging capacity?
also how much amperage the IDM draws when we run our engines at WOT?
and last how many RPM's our alternators can turn?
Powerstroke Racer is offline
post #2 of 16 (permalink) Old 12-14-2009, 02:51 AM
Caption This
444-4D's Avatar
Re: HP to run alternator
The alternator is the least of your problems, Freeze Plug. About 2 HP, at least 20,000 RPM.
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
444-4D is offline
post #3 of 16 (permalink) Old 12-14-2009, 03:18 AM
Village Idiot
southmike's Avatar
Could always change the pully size to keep it at a happy spot if there is one
southmike is offline
post #4 of 16 (permalink) Old 12-14-2009, 03:44 AM
PSN Mega Miler
crowz's Avatar
Best setup Ive seen was an a/c clutch on an alternator. When the box was set at the line for launch the alternator kicked out and after the run it was engaged again. Worked flawless.
2002 F250 SuperDuty Lariat PSD 7.3 Crew Cab 4x4 302,000+ miles.
, Valvoline Extreme Blue 5w40 Synthetic,
, Clifford Matrix 50.5x Alarm
, P3 Brake Controller, Swamps Injectors, PHP Tunes
crowz is offline
post #5 of 16 (permalink) Old 12-14-2009, 04:55 AM
I make smut cry
You planning on racing alternator outputs David?
Anymore info on this Crowz? Sounds pretty slick
Powerstroked162 is offline
post #6 of 16 (permalink) Old 12-14-2009, 05:30 AM
Grumpy Old Bitter Bastard
389SixPack's Avatar
watts= voltage*amps
1 hp= 745.7 watts
Watts = Volts * Amps (VA)
A 12 volt (nominal) alternator putting out 110 amperes creates 110a x 14.2v or 1562 watts.
One horsepower is equivalent to 746 watts. so for 1562 watts equvalent to 1562/746 = 2.1 horsepower.
You'll need a little more because of the alternator friction and resistance in the wire and other inefficiencies - so, for a horrible alternator running at 70% efficiency - 2.1/70% = 3.0 HP
I do not know the rpm for maximum output.
aka - Grumpy .. aka - Bubba Grump .. aka - Bubba .. aka - Grumpy Old F... . . A "slow" fatass 9K Dually.
389SixPack is offline
post #7 of 16 (permalink) Old 12-14-2009, 05:32 AM
PSN Mega Miler
crowz's Avatar
Was done on a S10 race truck a friend of mine has. I mentioned it as a joke and a few weeks later he had one made up and running
I dont see him very much anymore as he works out of state a bunch but I'll ask him what he used when I see him again. From the looks of it he had welded the front nose off a gm a/c compressor on it and had the pulley running welded onto it. The arch bracket that tightens the belt was bent back to keep it in line and the end that bolts to the bracket was shortened.
crowz is offline
post #8 of 16 (permalink) Old 12-14-2009, 05:38 AM
Busy Busy
Marty's Avatar
thanks nigel
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #9 of 16 (permalink) Old 12-14-2009, 05:44 AM
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
Why not look into some of the 16 volt batteries? Some are designed for total loss (no alternator) applications.
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
post #10 of 16 (permalink) Old 12-14-2009, 01:44 PM
CGMKCM's Avatar
I am also curious about the RPM's rating of alternators. Is it whatever the bearings are rated for?
On a class of Coast Guard boats that used alternators and inverters to supply power, we had a problem when high loads were applied for long periods of time the batteries would run down (boat at lower speeds). The DDEC system didn't behave well at low voltage.
We looked at different pulleys but the bearings speed ratings became an issue. We ended up with dual alternators and some fancy load sharing devices to solve the problem.
[SIGPIC][/SIGPIC]
2001 F-550 4X4 Lariat
BTS Tranny
PHP Phoenix chip
H2E Turbo With WW II
Adrenalin
Banks Intercooler and exhaust
In tank and pre-pump mods
Numerous minor Mods
Other Diesels
08 GL 320 CDI
02 VW Golf TDI
3054 Kioti Tractor
Kubota ZD 323
CGMKCM is offline
