Swapping Heads - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 12-12-2009, 04:38 AM Thread Starter
Swapping Heads
What all gaskets are needed to swap heads? I will be using factory gaskets and H11's that have been torqued once. Is a re-torque going to be necessary? Thanks.
bigjake0524 is offline
post #2 of 16 (permalink) Old 12-12-2009, 04:12 PM
Village Idiot
southmike's Avatar
Re: Swapping Heads
Since you will be disturbing the gaskets yes if you do the studs one at a time,
With the originals undisturbed no imho.
southmike is offline
post #3 of 16 (permalink) Old 12-12-2009, 05:46 PM Thread Starter
Re: Swapping Heads
I have some heads I bought from Danny (imelmo) and am wanting to swap them on. That is why I'll have to remove the heads.
post #4 of 16 (permalink) Old 12-12-2009, 07:15 PM
Re: Swapping Heads
were these the super ported heads?
mattr66 is offline
post #5 of 16 (permalink) Old 12-12-2009, 07:27 PM
JHill's Avatar
Re: Swapping Heads
IIRC I belive they are
E '99 F-350 CC LB, ZF6, IDP -T4i Mount, Comp. Fuel System, , Reg. Return, Comp Valve springs, ARP's, DI P- Rods, Adrenaline HPOP, Isspro's, Detroit Tru Trac
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #6 of 16 (permalink) Old 12-12-2009, 08:11 PM Thread Starter
Re: Swapping Heads
Yes, they are the super ported heads with dual valve springs and the intakes are coated as well.
post #7 of 16 (permalink) Old 12-12-2009, 10:06 PM
Layson's Avatar
Re: Swapping Heads
Are you pulling the engine? or doing it in the truck?
Layson is offline
post #8 of 16 (permalink) Old 12-12-2009, 10:32 PM Thread Starter
Re: Swapping Heads
I'm either pulling the engine or the cab don't want to try it in the truck.
post #9 of 16 (permalink) Old 12-12-2009, 11:36 PM
Layson's Avatar
Re: Swapping Heads
yes it does suck pulling the heads in the truck...
Layson is offline
post #10 of 16 (permalink) Old 12-13-2009, 12:44 AM
cota's Avatar
Re: Swapping Heads
Holler if you need any help.
2000,CC,4x4,auto
some bolt on stuff from Bean & BTS
Some used and some home made stuff
463hp/991tq 10/01/05 mustang dyno 10k rollers
458hp/923tq 04/14/07 dynojet dyno
490hp/1025tq 03/08/08 mustang dyno 10k rollers
03/08/08 1st runs ever, 13.5 & 13.264 @ 100.65mph screwing up both launches, 7600#'s, #2 only
cota is offline
