What Do You Think This Is? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 12-11-2009, 04:48 PM Thread Starter
AllYourBaseAreBelongToUs
imelmo's Avatar
Got a buddy with an '02 F350 auto 4x4 cc short-bed. Truck has a DI chip, head studs, hi-torque injectors, intake, exhaust (stock turbo).
Truck had been running great. He was driving about 25mph thru a school zone the other day when all of a sudden it started bellowing out a bunch of white smoke.
Now when you try and crank it, at first it makes like a loud "clank" type noise, but if you crank it a couple more times it'll start but run a little rough and keep bellowing smoke. It also has either oil or fuel coming out of the exhaust. I'm assuming it's oil because there's almost no oil in the crank-case now, although the oil coming out of the exhaust has more of a thinner diesel feel.
Any ideas?
EMPIRE DIESEL, PERFORMANCE TRUCK PRODUCTS, CEN-TEX DIESEL PERFORMANCE, AND DIESEL INNOVATIONS
ALSO LOTS OF HELP FROM (IN NO PARTICULAR ORDER) TWISTED DIESEL PERFORMANCE, FCDP, ITP, MATT WITH GEARHEAD, ERIC WITH INNOVATIVE, DOUG WITH GOGO DIESEL, CASS WITH FULL FORCE DIESEL, AND SWAMP'S
2005 F350 Fat-Butt Truck
2004 ECSB Procharged F250
imelmo is offline
post #2 of 9 (permalink) Old 12-11-2009, 04:50 PM
theSLEEPER's Avatar
Re: What Do You Think This Is?
O-rings? What is a hi-torque injector?
theSLEEPER is offline
post #3 of 9 (permalink) Old 12-11-2009, 04:52 PM
fbilly420's Avatar
maybe an injector poped loose and is leaking oil into the cylinder. Maybe the "clank" is one or more cylinders have oil in them. I would start by pulling the valve covers and make sure the injectors are all seated.
2001 F250, CCSB, 4X4, Auto, Forged rods
Lots of go fast parts and still slow.
2001 F250, STD cab, 2WD
Frame is a little shorter now
workin on body
engine build underway
fbilly420 is offline
post #4 of 9 (permalink) Old 12-11-2009, 05:03 PM
The Fireman
big_stroker's Avatar
I'm thinking it might have broken an injector hold down bolt and the injector is not seated all the way.
big_stroker is offline
post #5 of 9 (permalink) Old 12-11-2009, 05:27 PM
does the smoke smell like raw fuel? if so then its probably a cracked injector nozzle
2013 ccsb 4x4-stock
99 ccsb 4x4- built to the hilt, wife's DD!
Short Bus is offline
post #6 of 9 (permalink) Old 12-11-2009, 06:54 PM Thread Starter
imelmo's Avatar
That's what I'm leaning towards, but the oil on the ground doesn't have a very strong smell of fuel. But then again I'm kind of congested right now.
imelmo is offline
post #7 of 9 (permalink) Old 12-11-2009, 07:05 PM Thread Starter
imelmo's Avatar
http://www.diperformancetransmissions.com/inhopein.html
imelmo is offline
post #8 of 9 (permalink) Old 12-11-2009, 10:18 PM
What else?
smokyred's Avatar
Sounds like it's having a hydrolock initially. I would do as the others have said.
Dave
smokyred is offline
post #9 of 9 (permalink) Old 12-11-2009, 11:00 PM
fueled by Colecovision
golfer's Avatar
Garage
injectors not installed properly...
basically the injectors weren't seated ALLLLLL the way down into the cyl bores...and/or bolted down securely.
The truck was probably good for a few days/weeks (dep. upon how tight/loosely they were installed)...until the combustion leaked up past the (uncrushed) copper washer...& burned the injector o-rings allowing the fuel (pump) pressure...to go straight into the cylinder...hydro-locking the cylinder.
*it could be a cracked nozzle...but cracked 7.3 nozzles are RAAAARRRRRRRRREEEEEEEEEE
pull VC's, lay a straight edge across the 4 injs to see which one(s) is high
golfer is offline
