dp chip ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 12-10-2009, 04:18 AM Thread Starter
I like turtles
NE-STROKE's Avatar
dp chip ?
Will a dp f5 chip from a early 99 work in other year 7.3s?
NE-STROKE is offline
post #2 of 13 (permalink) Old 12-10-2009, 04:24 AM
BadDogPSD's Avatar
Re: dp chip ?
Yes, but it will need to be reprogrammed to match your PCM code.
2013 F350 CC LB Lariat 4x4
BadDogPSD is offline
post #3 of 13 (permalink) Old 12-10-2009, 04:24 AM
GoNavy!
DcMoore999's Avatar
Re: dp chip ?
Just depends what the PCM code is.
2000 F-250, RCLB, Auto!!
DcMoore999 is offline
post #4 of 13 (permalink) Old 12-10-2009, 04:27 AM Thread Starter
I like turtles
NE-STROKE's Avatar
Re: dp chip ?
How does that work cause when I ordered the chip jody never asked for any of that? Did not give him vin or anything.
thanks
post #5 of 13 (permalink) Old 12-10-2009, 04:30 AM
GoNavy!
DcMoore999's Avatar
Re: dp chip ?
I'm not sure man, everytime I've heard of any body ordering a chip they needed the pcm code.
post #6 of 13 (permalink) Old 12-10-2009, 04:39 AM
greenbeast's Avatar
Re: dp chip ?
Most just need a year/transmission type and they can program it.
greenbeast is offline
post #7 of 13 (permalink) Old 12-10-2009, 04:43 AM Thread Starter
I like turtles
NE-STROKE's Avatar
Re: dp chip ?
So will it work in a 02 that is has the same transmission?
post #8 of 13 (permalink) Old 12-10-2009, 04:45 AM
greenbeast's Avatar
Re: dp chip ?
You will have to re-program it. Early 99 is diferent than a late one and so on...
post #9 of 13 (permalink) Old 12-10-2009, 04:47 AM
GoNavy!
DcMoore999's Avatar
Re: dp chip ?
I see
post #10 of 13 (permalink) Old 12-10-2009, 08:09 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: dp chip ?
You will have to re-program it. Early 99 is different than a late one and so on...
Most chips will work from 99.5 to 01, and from 02-03... A chip from a 01 MAY work on a 2002-2003, but some functions will not work properly
Best bet is to tune to the PCM family you have...
E99 is a beast into its own.
Swap your PCM out for a PMT and you will be much happier!
Joe
CSIPSD is offline
