Is my new GTP38R too loose? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 12-10-2009, 01:58 AM Thread Starter
hotrodtodd's Avatar
Just picked up my new turbo but it seems a little loose radially on the shaft, you can grab it at both ends and it seems a bit loose??? Theres no in and out play, just up and down. I know the bearings will take up some oil but it seems excessive any thoughts?
hotrodtodd is offline
post #2 of 11 (permalink) Old 12-10-2009, 02:08 AM
ELKHUNTER's Avatar
Re: Is my new GTP38R too loose?
They seem loose, but its fine.
Josh
2000 F350 205,000
STAGE II SPLITS 100%
STEALTH SRP1
TYRANT TUNES
38R TURBO
BTS VALVE BODY
WALBRO 392
SCANGAUGE
ISSPRO
MORE STUFF
ELKHUNTER is offline
post #3 of 11 (permalink) Old 12-10-2009, 02:12 AM
aggie's Avatar
the 38r's will seem pretty loose. as long as its not hitting the housings it sounds pretty typical.
[SIGPIC][/SIGPIC]
aggie is offline
post #4 of 11 (permalink) Old 12-10-2009, 02:16 AM
Winners never quit!
Spray7.3's Avatar
The 38r I dealt with was just the same.
Dustin. 96 F250 XLT.
"Underestimated"
Spray7.3 is offline
post #5 of 11 (permalink) Old 12-10-2009, 02:18 AM Thread Starter
hotrodtodd's Avatar
I wish my camera was here to show better, I know SOME play but really it doesnt seem right with the amount its moving?? I read some have the same but others tighter, what gives?
post #6 of 11 (permalink) Old 12-10-2009, 02:39 AM
I feared the same when i bought mine used. It had more play than my stock bushing turbo. It didn't touch the housing anywhere and the play went away when I got some oil in it. Works perfectly fine.
2003 Fire engine red F350 6.0 CCLB DRW Lariat.
Blue fuel spring, coolant filter, EGR delete, Banjo bolts, Rotella T 5-W40, ARP, DE 4" turbo back, Farmers 175/75's, SCT with Vivian's tunes.
Dave R is offline
post #7 of 11 (permalink) Old 12-10-2009, 02:59 AM
fueled by Colecovision
golfer's Avatar
Garage
up and down play is ok, as long as it can't hit the housing.
when the center section is pressurized with oil...the shaft is centered on the bearings.
in & out play (more than a few thou) is a different story...
golfer is offline
post #8 of 11 (permalink) Old 12-10-2009, 03:12 AM
CumminsTrader's Avatar
They use Hydro-Dynamic bearings like Holset. Axial and radial play is OK. Just like stated, the pressurized oil causes the shaft to center. Most oil clearances between bearing/shaft surfaces are anywhere from 1-3 Thousandths. As long as the wheels are not hitting the housing, most likely the turbo is in spec. If you use a dial indicator, Garrett should be able to supply the service limits and you can verify if you are really worried.
Cory
1995 F350 CC DRW XLT 2WD 5-Spd w/ BD Exhaust Brake 225K Mi, HyperMax Stage 2 Kit, HyperMax EGT & Boost Gauges, Riffraff / Tymar Intake, HyperMax Intercooler, HyperMax 330HP chip, Adrealine HPOP & Braided Lines, Melling M208 LPOP and HyperMax 4" Exhaust. Coming Soon: DP-Tuner F-6 and custom electric fuel system.
CumminsTrader is offline
post #9 of 11 (permalink) Old 12-10-2009, 04:48 AM Thread Starter
hotrodtodd's Avatar
Ok thanks guys, I will measure the up and down + in and out tommoro at work I dont have my dial here at home. Its funny that more and more parts are starting to come together (on my shelf) that I am getting more worried about all that could go wrong
post #10 of 11 (permalink) Old 12-10-2009, 12:47 PM
That's usually how it goes. You probably get the same feeling I get when it's done and ready to start. "Did I forget anything" "Is everything installed" "Do I have all my tools" " Is this part going to work since i got it used".
Good luck with it.
Dave
Dave R is offline
