Boost Relief Valve - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 12-09-2009, 04:02 AM Thread Starter
SiC sEnSe's Avatar
Boost Relief Valve
Ok so Im thinking of getting this since I have my chip coming and also just wondering if it makes noise like a BOV?? Just wondering cause if the boost relief valve makes the same sound and I'll save me green since people say it's a waste of money anyways
00 f250 7.3 powerstroke 4x4:: RBP 4" TB with a RBP 4 to 5" tip::TS Chip with PHP tunes
SiC sEnSe is offline
post #2 of 15 (permalink) Old 12-09-2009, 04:19 AM
Dieselized
bluetech151's Avatar
Re: Boost Relief Valve
All you need is this http://www.itpdiesel.com/store.php/products/Overboost
BOV are for ricers
You call yourself a mechanic, you can't even fix a mechanical pencil.
bluetech151 is offline
post #3 of 15 (permalink) Old 12-09-2009, 04:30 AM
NVJAY775's Avatar
BOV are for ricers
I think all that does is keep your PCM from picking up on overboost and turning on the SEL. Who sounds hotter? overboost, or the SEL? Either way it sounds like trouble for PCM.
Silver 00 4x4 ex cab lb
305 70 16's
DIY Tymar
5" stack
Modded H2E from ctperformanceinc.com
180cc AA's
DP Tuner F5
Full Jimmy Converse trans / converter
6.0 trans cooler
NVJAY775 is offline
post #4 of 15 (permalink) Old 12-09-2009, 04:31 AM Thread Starter
SiC sEnSe's Avatar
BOV are for ricers
Yeah I was thinking of gtting this one
Boost Relief Valve +
looks like I'll be buying both
post #5 of 15 (permalink) Old 12-09-2009, 04:33 AM
just a welding fool.
Hawker's Avatar
that doesn't make noise, it just fools the computer into thinking you're below allowable boost levels for fueling. you can do the same thing with a $12 air pressure regulator from home depot spliced into the MAP line.
Swamps
Gearhead Tuning
Diesel Innovations
Hawker is offline
post #6 of 15 (permalink) Old 12-09-2009, 04:45 AM
Dieselized
Sorry, I just think too many people buy BOV around here simply because of the noise they make when shifting. A BOV should be used as a safty and performance device not a noise maker.
And Hawker is right about the home depot made regulator
post #7 of 15 (permalink) Old 12-09-2009, 04:56 AM Thread Starter
SiC sEnSe's Avatar
There are some reasons I want it but mainly for the sound here this is from the website turbo guard
Closing the throttle suddenly when the engine is under#load can result in turbo damage. BDís TurboGuard blow-off#valve protects your stock or aftermarket turbo from surging#and possible compressor wheel explosions. This new advanced#TurboGuard kit features adjustable valve# opening#pressure and a microprocessor with six different custom#settings, including valve opening pressure, activation sensitivity,#clutch cancellation, and more.
BD Power - Product: Turbo Guard
post #8 of 15 (permalink) Old 12-09-2009, 05:05 AM
You should go back and read the Dieselsite's response as to why using a regulator from Home Depot is a bad idea. A regulator will prevent the SES light due to high boost pressure but I will not allow the map to see the correct pressure you need in order to access the correct fueling tables. Go read Bob's site its near the bottom where he specifically address this.
pilot4life is offline
post #9 of 15 (permalink) Old 12-09-2009, 05:07 AM
My truck has been dumping excess boost out the intake for 76,000 miles with no issue. If you want it for the noise then go for it.
post #10 of 15 (permalink) Old 12-09-2009, 05:33 AM
Hawker's Avatar
so as a stock sensor, you're good up to 25 psi, which from what i've been hearing is about the limit for the stock turbo, right?
Swamps
Gearhead Tuning
Diesel Innovations
Hawker is offline
