AIH DELETE - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 37 (permalink) Old 12-09-2009, 12:52 AM Thread Starter
I Wanna Go Fast
White Sled's Avatar
AIH DELETE
Alright I have been looking every where for this and I can not find it so I thought that I would throw up a thread on the topic. You know how you can delete the AIH I have heard somewhere that you can use a dodge drain plug but I can not remember what size the plug is (22mm I think) or what year dodge truck to look for \
Thanks any help would be nice
White Sled is offline
post #2 of 37 (permalink) Old 12-09-2009, 01:00 AM
Ramond is a ritard
stutterinwithastack's Avatar
Re: AIH DELETE
iirc its a 01 dodge i just took mine out and taped up the wires so they wont arc
ebpv delete, 4" down pipe, 6" single stack, dp tuner, edge evo for gauges, 6637 intake, exhuast and ebpv delete done by me. pacemaker\defib with high performance tune.
stutterinwithastack is offline
post #3 of 37 (permalink) Old 12-09-2009, 01:01 AM Thread Starter
I Wanna Go Fast
White Sled's Avatar
Re: AIH DELETE
Oil drain plug right they dont have an drain plug on the tranny iirc
post #4 of 37 (permalink) Old 12-09-2009, 01:20 AM
theSLEEPER's Avatar
Re: AIH DELETE
Yeah. Oil drain. You'll be able to tell the diff. I bought the wrong one the first time. The right one is big around and shallow.
theSLEEPER is offline
post #5 of 37 (permalink) Old 12-09-2009, 02:19 AM
Ramond is a ritard
Re: AIH DELETE
drill a hole in the center for your boost guage if you have one that makes it nice
post #6 of 37 (permalink) Old 12-09-2009, 02:42 AM
Custom Trailer Sales
TrailerHauler's Avatar
Re: AIH DELETE
You can cheap out like i did, take out the AIH chop off the end and screw it back in. Pull out all assosiated wiring accordingly.
1999.5 F350 PSD CC Dually 05' Conversion
Stage I's - Gearhead Tuning - BTS - PCS
F550 rear suspension
1999.5 F350 PSD S/C 6spd Dually
R.I.P. Will Iott - "This ain't no practice run"
TrailerHauler is offline
post #7 of 37 (permalink) Old 12-09-2009, 02:56 AM
Re: AIH DELETE
xtremediesel sells one. CFM+ (CFM PLUS) Air Intake Heater Delete Plug
2006 f-250 ext cab swb, 127,000mi, Egr delete, 4" tb exhaust, edge juice w/ cs.
Ryan
dp_stroker is offline
post #8 of 37 (permalink) Old 12-09-2009, 07:20 AM
TARM's Avatar
Re: AIH DELETE
22mm x 1.5 + washer 5.9 oil pan plug: Car Quest, Napa, Advanced, etc... usually have them hanging on the wall racks with other generic quick fix parts. You may need to ask if you do not see them. I like the standard flat bolt face ones instead of the hex / Allen key ones. Cost is a couple dollars for the generic ones, IIRC. IMO, its best to trace back and remove the wires at the posts. Black Grounded and the Red on the solenoid post. That same post also has a blue wire on it. Make sure to keep that one attached / reattached. With all the OEM stuff I remove I label and bag it up just in case.
If you want to order online: http://www.dieselsite.com/index.asp?...PROD&ProdID=48
Instructions are there as well.
TARM is offline
post #9 of 37 (permalink) Old 12-09-2009, 10:18 AM
Metal - It kicks your ass
Re: AIH DELETE
I got mine from Car Quest. It was like 13 bucks if i remember.
Modded L99
dirtboy25 is offline
post #10 of 37 (permalink) Old 12-09-2009, 12:55 PM
Re: AIH DELETE
What's the purpose of deleting it? I see alot of people talk about it but don't understand its purpose to have or not.
Thanks
Dave
2003 Fire engine red F350 6.0 CCLB DRW Lariat.
Blue fuel spring, coolant filter, EGR delete, Banjo bolts, Rotella T 5-W40, ARP, DE 4" turbo back, Farmers 175/75's, SCT with Vivian's tunes.
Dave R is offline
