Charge Air Temp Gauge - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 12-08-2009, 01:57 AM Thread Starter
Got Bost???
NyCowboy87's Avatar
Does anyone make a charge air temp gauge? I was thinking of just using a water temp gauge but not sure how well it would work.
95 Ex. Cab Long Bed 4x4. Built.
01 Ex. Cab Long Bed Dually 4x4 6 Speed. Intake, Exhaust, Super Chips Tuned
Tow Mule
NyCowboy87 is offline
post #2 of 9 (permalink) Old 12-08-2009, 02:28 AM
Grumpy Old Bitter Bastard
389SixPack's Avatar
Re: Charge Air Temp Gauge
Water temp gauge won't read high enough. I use a digital EGT guage with pyrometer in the Y right after Compressor output, and use a standard temp gauge in the Y right befor the intakes. I have seen Comp air temps getting close to 450 *F.
aka - Grumpy .. aka - Bubba Grump .. aka - Bubba .. aka - Grumpy Old F... . . A "slow" fatass 9K Dually.
389SixPack is offline
post #3 of 9 (permalink) Old 12-08-2009, 02:35 AM
Crazy Redneck
UNCOOL's Avatar
I have one after the intercooler in the intake Y. Its not worth the money, I was curious, and I seldom see over 100 degrees at full boost. Was a waste of $200.
Marc
2000 F350 CC dually auto
Little air, fuel and oil and a BTS.
533/1050 5-8-10
#32
UNCOOL is offline
post #4 of 9 (permalink) Old 12-08-2009, 05:07 AM
Moderator
Blowby's Avatar
I have the Autometer Two-Stage Air Temp guage w/ Max Temp Recall. I did some testing on DI's IC in April 2006. One sensor pre and one post IC. Worked great.
I will be putting it on again to check stage I and stage II temps from the turbos as soon as the snow melts.
Blowby is offline
post #5 of 9 (permalink) Old 12-08-2009, 07:37 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
I have a Isspro air temp on the pre IC side, never got around to installing one post other then temp...
Joe
CSIPSD is offline
post #6 of 9 (permalink) Old 12-08-2009, 12:43 PM Thread Starter
Got Bost???
NyCowboy87's Avatar
Thanks guys. I wanted to check first and second stage temps and with the 2nd stage not being cooled I wanted to see just how hot it got. My guess is probably around 3-400* so I might do an air to water ic.
Tow Mule
post #7 of 9 (permalink) Old 12-08-2009, 12:48 PM
Do you have a part number for that gauge? I couldnt find one on their site.
03 E-350 7.3, forged rods, exhaust ported heads, comp 910's, 38R/47, 4.10LS, stealth twin pumps, 300cc hybrids from Swamps, h-11's, racerx trans and TC, Swamps tunes, water...
rpm-inc is offline
post #8 of 9 (permalink) Old 12-08-2009, 01:07 PM
PSN nerd
you could just get you a fluke 51 and buy a couple air probes or just buy the air probes and hook up to a digital multimeter that has a k or j thermocouple plug it would be less money there if your just doing it for testing
spatechnique makes one that is a 2 channel but its like $350
97 F250SC 4X4 4 LINKED ON AIR <- FOR SALE!!!!!!
00 F350CC 4x4 I NEED A FLATBED FOR IT!!!!! LET ME KNOW IF YALL KNOW ANYBODY THAT HAS ONE
JAKE is offline
post #9 of 9 (permalink) Old 12-08-2009, 05:05 PM
Moderator
Blowby's Avatar
Only link I could find about $300
Autometer Ultra Lite 2 1/16 Intake Temperature 30-400 Gauge
Powered by digital microprocessor-controlled, rugged stepper motor drives & laboratory grade sending units, Full Sweep Electric Gauges are the BEST gauges available. They combine Extreme Durability & Readability of 270 degree sweep mechanical gauges w/ the Easy Installation & Safe Operation of short sweep electrics. Track Tested & Race Proven, these units use precision senders to keep hazardous fluids out of the driver compartment, and perform gauge calibration and sensor diagnostics at power up for Extreme Accuracy, every time. Most units compatible w/ Auto Meter Data Logger for the ultimate race info center.
30 - 400 deg. F
Air-Core meter movement.
Includes 8 ft. tubing or wiring harness.
Includes temperature module and two Type K Thermocouples.
Blowby is offline
