Attention those with AutoEnginuity and Single-Shot Injectors! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 36 (permalink) Old 12-07-2009, 02:42 AM Thread Starter
It would be easiest for me to evaluate this data if you have a stock HPOP (15* or 17*) simply because I already know the specifics of those pumps (pump/engine gearing and cc/revolution of the pump). If you know this information for your custom HPOP then I could still make use of your data!
I'd like to ask a favor of those with single-shots. I'm doing some analysis of HPOP data. If you are willing to take a few minutes of your time ... please take a data log in AutoEnginuity of Engine RPM, Volume Fuel Desired, ICP pressure, and IPR Duty Cycle %. What I'm looking for is about a minute or so of data recorded at idle (fully warmed-up)... after that transition to a high idle, preferably with EBPV closed, and the transmission in gear for about a minute. Basically ... I just want a good set of data at a constant RPM, unloaded (idle, in neutral) ... and a good set of data at a higher constant RPM, loaded (high-idle, EBPV closed, in gear).
If you'd repeat this cycle one more time for roughly 4-5 minutes of recorded data total, I would really appreciate it! E-Mail the csv file to [email protected].
scraph is offline
post #2 of 36 (permalink) Old 12-07-2009, 03:06 AM
fueled by Colecovision
golfer's Avatar
Garage
Re: Attention those with AutoEnginuity and Single-Shot Injectors!
errr...
#1 not all pumps are created equal
#2 not all injectors are created equal
#3 not all IPR's are created equal
#4 not all tuning is created equal
trying to compile the data on PW, ICP, rpm, IPR%, etc...is going to do nothing for you unless you had THE pump, THE set of injs, THE IPR, and THE tuning associated with each set of data...and could test EACH of those components.
golfer is offline
post #3 of 36 (permalink) Old 12-07-2009, 03:53 AM Thread Starter
I suppose if you're assuming that I'm using the data for something which it would not help me with, then you are correct. However, I happen to be using the data for something which it would help me with ... so I would still like the data from anyone and everyone who is willing to provide it. Thanks for your confidence though.
scraph is offline
post #4 of 36 (permalink) Old 12-07-2009, 04:02 AM
golfer's Avatar
Garage
if you are trying to provide data that supports the fact that there is a HUGE disparity between these trucks' HPOil systems...then I think you will get the data you seek.
golfer is offline
post #5 of 36 (permalink) Old 12-07-2009, 04:05 AM
OEM Moderator
Tom S's Avatar
So what are you working on? I agree with Dave that there are some variables there that make comparison difficult.
Tom S is offline
post #6 of 36 (permalink) Old 12-07-2009, 05:23 AM Thread Starter
I'm modeling the system mathematically. I'm modeling it so that I can design my own based on my needs. Putting real-world data into the model actually helps me to account for all the things that make each system different ... instead of complicating things.
Once I have enough data and I can model real-world behavior into it then I can use it to define what I need from an HPOP and a given set of injectors. I don't simply want an HPOP that's "big enough for even B-codes". I want an HPOP that's optimized for the specific set of injectors that I plan to install.
I'm not in this for ever increasing horsepower. I intend to optimize my engine. Modeling and data analysis is how I'm going to do that with this portion of the engine.
I want to see data from single-shots because I am running split-shots right now but intend to run single-shots. The data that I am getting makes sense with my model but I can see the influence of the split shot heavily and don't want to take the time to include split-shot behavior into the model ... since I'm not trying to design a split-shot system.
scraph is offline
post #7 of 36 (permalink) Old 12-07-2009, 05:33 AM
golfer's Avatar
Garage
...yeah, that seems 100% reasonable...no need to complicate things
golfer is offline
post #8 of 36 (permalink) Old 12-07-2009, 05:40 AM Thread Starter
One behavior that I think I'm finding ... I'm going to analyze more of my own data to confirm this ... is that the "oil thirsty" behavior of split-shots that we talk about is much more pronounced at injection shots less than the capacity of the injector. On my engine, I am seeing that the injectors start to require an amount of oil closer to that of a single shot as they are injecting more fuel. I'll keep looking.
scraph is offline
post #9 of 36 (permalink) Old 12-07-2009, 05:45 AM Thread Starter
*shrug* There's engineers who designed the 7.3L. You know how the stock pump seems to just barely support the stock sticks with a stock tune? That's on purpose. I like that. I want a pump that just barely supports the sticks I put in with the tune I'll be using. With this knowledge and possibly with the help of the DIESELSITE Overdrive I can design such a system.
scraph is offline
post #10 of 36 (permalink) Old 12-07-2009, 07:01 AM
sounds like your already complicating things.
but i hope the best for ya
02 f250
countryboyrob is offline
