Wast Gate Tuning - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 34 (permalink) Old 12-07-2009, 12:00 AM Thread Starter
3YLSYKR's Avatar
Wast Gate Tuning
I have an adjustable waste gate installed on my truck at the stock 2" mark for those who don't have gauges. I'm making 22lbs right now.
I think the fuel cut-off is 25lbs if I can remember right.
I wanna try to adjust it down in gap space and compress the spring for more boost. I'm just wondering if anyone runs one like this and what boost they are seeing from certain spring gap settings.
I have a boost fooler plug in for when or if I'll hit 25lbs and above so I'm not worried there. I am concerned about how much boost my truck will handle. I don't have head studs and as far as I know stock style trans.
I would appreciate any tips or help with this before I start to tinker and go too high and hurt something.
8" Lift
38" Toyo MT's
DIY Traction Bars
Zoodad-AIH Delete-Foil Delete
Adjust. Wastegate
ISSIPRO Performax Gauges
4" TB Magnaflow Exhaust w/ 5" tip
AFE stage 2 PG 7 W/Pre-Filter
Superchips Prgmr 150HP/225TQ
Oil X-over Line
Smoked Lights w/LEDs & HIDs
DIY 3 stage Water/Meth
CCV
6.0 IC
Transgo Shift Kit
Derale Trans. Frame Rail Cooler
3YLSYKR is offline
post #2 of 34 (permalink) Old 12-07-2009, 12:02 AM
Super Hauler!
Super_Hauler's Avatar
Re: Wast Gate Tuning
just wire it shut and when you hit the boost you want let off!
Super_Hauler is offline
post #3 of 34 (permalink) Old 12-07-2009, 02:24 AM Thread Starter
3YLSYKR's Avatar
Why would I do that? It's good to have a waste gate for protection of components. I can't wire this one.
8" Lift
38" Toyo MT's
DIY Traction Bars
Adjust. Wastegate
Oil X-over Line
CCV
6.0 IC
Transgo Shift Kit
3YLSYKR is offline
post #4 of 34 (permalink) Old 12-07-2009, 02:26 AM
PSA
mclean's Avatar
stock turbo?
mclean is offline
post #5 of 34 (permalink) Old 12-07-2009, 03:36 AM Thread Starter
3YLSYKR's Avatar
Yes I still have stock turbo, wheel, and housing as far as I know.
8" Lift
38" Toyo MT's
DIY Traction Bars
Adjust. Wastegate
Oil X-over Line
CCV
6.0 IC
Transgo Shift Kit
3YLSYKR is offline
post #6 of 34 (permalink) Old 12-07-2009, 02:13 PM
owner/president
dixieland-diesels's Avatar
Send a message via MSN to dixieland-diesels
I put a smaller stiffer spring inside of the spring that came with it.
03 lariat cc,4x4 7.3,DP-F5,36''MT,8"lift w/trac.bars,4"Silverline ss.exh,AFE II,Optimas,ATS housing,WW,Turbomaster,6.0 IC & tranny cooler,BTS,ISSPRO gauges,HPX,ITP RR,BRV+,Powerslots,WARN prem-hubs,coolant filter,ccv mod,08 mirrors,ARP's,mod.fuel & inj's.,Crower rods,AIH delete,AMSOIL fluids. ~waitn on the 38R~
dixieland-diesels is offline
post #7 of 34 (permalink) Old 12-07-2009, 09:54 PM
Slated4Greatness's Avatar
You will be fine up to 28 or so then the turbo is out of it's map and just starts moving hot air. 28 without studs is fine.
Which adjustable wastegate do you have?
2006 F350 Lariat Tow Boss W/training wheels.
SCT W/GH's tunes, ARP's, Blk & Heads milled, Strictly RR and aux coolant lines, 6" Aussies, Snow MPG-Max, BPD: VK688,EGR, W/Pump, and FICM, Coolant filt, Train Horns, CTS (Monitor only) + Autometer backups
RIP Muley 9-25-09
Keep on Honkin' Jerry 04-05-10
Slated4Greatness is offline
post #8 of 34 (permalink) Old 12-08-2009, 02:44 AM Thread Starter
3YLSYKR's Avatar
Why do that when it's adjustable?
8" Lift
38" Toyo MT's
DIY Traction Bars
Adjust. Wastegate
Oil X-over Line
CCV
6.0 IC
Transgo Shift Kit
3YLSYKR is offline
post #9 of 34 (permalink) Old 12-08-2009, 12:23 PM
owner/president
I personaly think their spring is to weak to achieve 32-35psi of boost.Its basicaly the last step you can do,next to wiring the gate shut and still get minimum movement.Works out good for me.
post #10 of 34 (permalink) Old 12-09-2009, 12:47 AM
Supercharged
Rockrunner86's Avatar
Send a message via Yahoo to Rockrunner86
Why with stock injectors would you ever want the wastegate to open?
99.5 F-350 6-speed Daily Driver/Tow Rig.
Engine - Empire Diesel Performance
Air - Empire Diesel Performance Compounds Procharger Primary / Garrett 38R Secondary
Oil- Swamps Gen-3
Fuel - B-codes
Rockrunner86 is offline
