H2E oil line leak help. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 12-06-2009, 08:08 PM Thread Starter
NVJAY775's Avatar
I have a leak on the lower oil line fitting area... Not sure if it's at the fitting into plate, or the compression into plate fitting. The fitting that threads into the plate was pre installed by hypermax. It had what looked and smelled like blue loctite on it. I removed it to check and will re-install. I just wanted to make sure it had sealant on it.
This next one I feel kinda dumb on. In the directions, it just says to install it (the oil line). I assumed it meant as-is with the rubber doughnuts between the flair and brass compression fitting. I thought it was kind of odd looking, because I haven't seen a fitting like that before. Meaning the rubber doughnut. Was I supposed to remove it? The top fitting sealed with it.
Thanks much guys
Jay
Silver 00 4x4 ex cab lb
305 70 16's
DIY Tymar
5" stack
Modded H2E from ctperformanceinc.com
180cc AA's
DP Tuner F5
Full Jimmy Converse trans / converter
6.0 trans cooler
NVJAY775 is offline
post #2 of 6 (permalink) Old 12-07-2009, 09:48 AM
Senior Member
HPAddict's Avatar
Re: H2E oil line leak help.
Tighten it down some more, and yes, the rubber stays on.
HPAddict is offline
post #3 of 6 (permalink) Old 12-07-2009, 02:27 PM
My return line leaks unless you put a little silicone on it before inserting it into the plate.
mattr66 is offline
post #4 of 6 (permalink) Old 12-07-2009, 02:48 PM Thread Starter
NVJAY775's Avatar
I'll try that too. Didn't get a look at it again yesterday after I put the oil (feed) line back on. It's still leakin though.
Thanks for the heads up!
Jay
305 70 16's
DIY Tymar
5" stack
180cc AA's
DP Tuner F5
6.0 trans cooler
NVJAY775 is offline
post #5 of 6 (permalink) Old 12-08-2009, 04:57 PM
MacAssassin
God dammit jay, now i need an H2E kit.
2002 F-250 4x4 CCSB+, BTS Trans, Gtp38r turbo,Non EBPV pedistal, Bellowed ceramic coated uppipes, Rosewood AA single shot 180cc injectors, Tony wildman tunes, 4" turbo back exhaust, Tymar intake, zoodad mod,AIH delete, 315/75/16 tires, 3.73 gears.
2000 Ford F-250 XCLB- stock (just bought)
MacAssassin is offline
post #6 of 6 (permalink) Old 12-09-2009, 04:20 AM Thread Starter
NVJAY775's Avatar
Sunshine! What are you up to? I wish the roads would melt off so I can light this thing... But it sounds like we may get more the end of the week. When the roads melt off I'll give ya a call, so we can go for a ride.
I still haven't worked on it. I think the oil drain is the culprit. I'll try sealing it as soon as I get a chance and post back.
Thanks guys!
Jay
305 70 16's
DIY Tymar
5" stack
180cc AA's
DP Tuner F5
6.0 trans cooler
NVJAY775 is offline
