A I R... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 54 (permalink) Old 07-31-2007, 02:40 AM Thread Starter
Banned
A I R...
Some pics for gregbob.
Underhood
Hotside inlet to GT47-88
Hotside Downpipe/ Intermediate Pipe
Charles is offline
post #2 of 54 (permalink) Old 07-31-2007, 02:44 AM
Re: A I R...
Thanks
Looks good dude. Powdercoat those IC pipes and it's bitchin.
Good job, my guess you could support 600+ on fuel only. If the rod cooperated.
gregrob is offline
post #3 of 54 (permalink) Old 07-31-2007, 02:56 AM
Subject Matter Expert
PowerstrokeJunkie's Avatar
Re: A I R...
Thats unique, i can't say i've seen it done that way. That's alot of heat, very close to the hood... are you going to be doing anything with that? What kind of engine internals do you have to support that huge ass charger?
NICE
Stock
PowerstrokeJunkie is offline
post #4 of 54 (permalink) Old 07-31-2007, 11:59 AM Thread Starter
Banned
Re: A I R...
I was surprised with the heat, or lack thereof actually. I had planned to ceramic coat everything inside and out, but now I'm not sure I need to. The downpipe runs less than a quarter of an inch from the (plastic) heater box and I have been right up near 1200 degrees for minutes at a time (pulling monteagle at speed) and it shows zero sign of heat. I just don't think that much heat is making its way past the first turbine housing. I woln't worry about it until I start towing with it again. I could see that getting those pipes hot again.
Engine has never had the heads off. Stock powerstroke plus studs and valvesprings/pushrods.
Should be good for 700+ on fuel and 600-650 reliably.
That turbo should be good for 1000hp depending on how you use it. Same turbo does right at 1200rwhp on fuel on my buddies car, and has done over 1400rwhp on fuel on some others.
Charles is offline
post #5 of 54 (permalink) Old 07-31-2007, 01:07 PM
Wheelie Dude
bean's Avatar
Send a message via AIM to bean
Re: A I R...
Looks good Charles. I do miss the twins that I had at one time. Its just that sudden unbelievable boost that makes them fun.
Smokin' Hot Hooker- 2002 F350 Dually 4x4 6spd- 5.9 CR-
BDP Drag Truck- 81 C10-5.9CR, BTS 4R, Goes Fast
Beans Diesel Performance
bean is offline
post #6 of 54 (permalink) Old 07-31-2007, 11:47 PM
Donkey pumper
HeeHaw's Avatar
Send a message via AIM to HeeHaw
Re: A I R...
whats that #%ick got for fuel?
1964 706 IH with a 05 Cummins motor Smartyfied.
"I'm spitting in your face cause I'm a dominating you!" -Hank 3
HeeHaw is offline
post #7 of 54 (permalink) Old 08-01-2007, 12:25 AM
Re: A I R...
B-codes, unless he changed them.
gregrob is offline
post #8 of 54 (permalink) Old 08-01-2007, 12:32 AM
Re: A I R...
b codes+ big boost+ stock rods = bye bye rods LMAO
Charles it does look good though!
2013 ccsb 4x4-stock
99 ccsb 4x4- built to the hilt, wife's DD!
Short Bus is offline
post #9 of 54 (permalink) Old 08-01-2007, 12:58 AM
HRT Performance
HotRodTractor's Avatar
Re: A I R...
I want multiple turbos........
Seriously, you got a good looking setup. I need to borrow some of those ideas for my tow truck.
Jason H.
2006 Dmax MPI compounds
2015 VW Jetta TDI
2006 VW Jetta TDI
HotRodTractor is offline
post #10 of 54 (permalink) Old 08-01-2007, 02:32 AM
Body Type: MULE
CATdiezel's Avatar
Re: A I R...
Chuck looks good,
Glad to see you around this site needs a "write UP" person and I think your the man to do it. Have personally seen you write literal BOOKS on TDS before you multiple personalitys and constant bans .
2011- F250 PSD CCSB 4x4 HS PERFORMANCE Tuning DPF OFF EGR OFF TRUCK HAPPY DRIVER HAPPY
your #1 NON-Cult member of the USA Government JustinM.
CATdiezel is offline
