Help? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 08-06-2015, 03:45 PM Thread Starter
Help?
My 2001 F250 (7.3) has, in the past two weeks, started turning over rapidly but not starting. Only when the foot pedal is depressed several times while cranking does the engine fire. Any ideas? This thing has been bulletproof until this with only normal oil & filter changes and NO engine issues at all. Everything on the truck is original.
stant is offline
post #2 of 5 (permalink) Old 08-06-2015, 03:53 PM
Bugman's Avatar
Re: Help?
Without knowing anything else about the truck I would start by testing the glow plug relay and the glow plugs.
Pumping the pedal does nothing until the engine is running.
Bugman is online now
post #3 of 5 (permalink) Old 08-06-2015, 04:54 PM Thread Starter
Re: Help?
Thanks, I will have that looked at. The depressing of the "pedal" seems to be coincident with the engine starting, but as I understand it that is a wire system not a mechanical system, but it sure seems like after much pedal stomping it will finally light.
Thanks again at least now I have a starting point.
stant is offline
post #4 of 5 (permalink) Old 08-07-2015, 10:45 PM
Carolina444's Avatar
Re: Help?
codes?
E99 f250 2wd cclb,257k, tymar intake, stock turbo w/ riffraff billet wheel, PIS 230/100,regulated return, hbjr, pmt1, hydra w/dynoproven and powerstruck tunes, 140v Idm, 4" exhuast, isspro's, ccv, ebpv delete, jwvb w/6.0 cooler
Coming soon: BASB
Carolina444 is offline
post #5 of 5 (permalink) Old 08-08-2015, 02:54 AM
7.3diesel94's Avatar
Re: Help?
I had the same issues but never pumped the pedal on the truck it ended up being the cps
7.3diesel94 is offline
