Turbo upgrade - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 34 (permalink) Old 07-11-2015, 03:15 AM Thread Starter
Turbo upgrade
Hey guys I'm pretty new to diesels and just trying to figure out the best route for me to take. I had a deal with a friend of mine for a brand new ats ported turbo housing but it fell through. So I'm curious if you all think it is worth me buying one from an online site or should I just save up for the gtp38r? If I should save up for it with my current mods can my motor handle it since I do not have forged rods?
Thanks
02 f350, 4" turbo back straight pipe exhaust, dp tuner f5 chip, transgo shift kit, tymar intake, gauges, 35" tires.
mad_max is offline
post #2 of 34 (permalink) Old 07-11-2015, 03:34 AM
Moderator
Sbluke55's Avatar
Re: Turbo upgrade
Thanks
Do you ever plan on upgrading injectors.
01 f-250, Standard
Sbluke55 is online now
post #3 of 34 (permalink) Old 07-11-2015, 06:29 AM
CtG
Re: Turbo upgrade
The GTP38R is nice, but spendy if you aren't going to "need" it.
What are your goals?
Family Rides-
99.5 F250 PSD SC 4x4 SD: BTS, SS 4" Exh, 6637, 6-pos chip, 4" lift, Reg. Return, FFD 160CC Single's, GTP38R, Adrenaline, Fuel Bowl Delete- 410HP/828TQ Wheel
02 Excursion 4x4 PSD: 4" DP-back w/ Aero-Turbine, Larry's Black Box, BTS
CtG is offline
post #4 of 34 (permalink) Old 07-11-2015, 09:32 AM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
Re: Turbo upgrade
IMO a 38R is better then a pimped out stock turbo. the 38R has no surge,takes more abuse,spools alot faster and flows 33% more air..work great with a stock truck and can make 500 hp with supporting mods..the only gain you get for a pimped out stock turbo is no surge..
Ron's power stroke is offline
post #5 of 34 (permalink) Old 07-11-2015, 09:53 AM
Don't EFN worry about it
Aljay's Avatar
Re: Turbo upgrade
I would not put any money into a stock turbo . Save your pennies get the 38r it's a bolt on deal . Hybrids and a 38r with decent tuning is a hella combo .
Tuned by T Wildman
Aljay is offline
post #6 of 34 (permalink) Old 07-11-2015, 12:01 PM
Moderator
Sbluke55's Avatar
Re: Turbo upgrade
If you never plan on upgrading to bigger injectors. The 38r is a waste of money. A billet wheel will be fine.
01 f-250, Standard
post #7 of 34 (permalink) Old 07-11-2015, 12:30 PM
Re: Turbo upgrade
i ask because im sure you know by running one your self..
tell me how 33% more air,lower EGT's faster spool up, less back psi even at 40 psi boost and a stronger center section that is very reliable not worth the money? you get more low end power then a pimped out stock turbo will give you just by putting it on the truck..
post #8 of 34 (permalink) Old 07-11-2015, 02:00 PM
Aljay's Avatar
Re: Turbo upgrade
Not a lot of folks run bigger than 230-250 CC sticks ! How is it a waste of money
My 230 A codes, big oil , good tuning ,a 38r makes for a potent but usable truck !
Tuned by T Wildman
Aljay is offline
post #9 of 34 (permalink) Old 07-11-2015, 02:17 PM
Moderator
Sbluke55's Avatar
Turbo upgrade
I can't see justifying a $1500 turbo on a stock injector truck. If you tow a lot and heavy. It's a great upgrade. But just for a daily driver and light towing a billet wheel is a great upgrade.
I personally never had one. I just pimped out my stock turbo. I do agree on it being stronger at higher boost levels but again on a stock truck your not going to see high enough pressures to damage your stocker.
If you do upgrade to some 160/30 or bigger, then upgrade to the 38r.
01 f-250, Standard
post #10 of 34 (permalink) Old 07-11-2015, 04:47 PM
Caption This
444-4D's Avatar
Re: Turbo upgrade
The exact application a 38r turbo was designed for was a truck with stock injectors and a chip, an engine with around 300 HP.
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
444-4D is offline
