Trans cooler - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 07-02-2015, 04:17 AM Thread Starter
tractorman1215's Avatar
Trans cooler
Hey guys while I'm ripping apart my radiator support on my 1996 f250 7.3 I figured might as well put an upgraded trans cooler on it. I looked at riff raff diesel and xdp. I'm considering the misimoto mmoc-f or the derale 13750. The truck has 88k and I don't want to blow my e40d. The trans tech at the ford dealer I work for said best thing is to keep these trans cold. So any suggestions.
tractorman1215 is offline
post #2 of 10 (permalink) Old 07-02-2015, 08:02 AM
CtG
Re: Trans cooler
Honestly not sure if the 6.0 cooler will bolt in an OBS, but if it will, either 6.0 cooler is a great upgrade. The smaller one is still a big improvement, the large one is bigger than the radiator on my Toyota.
Tru-Cool 4739-1 works great as well. Big Red (99.5) has that one. Dieselsite sells it.
Family Rides-
99.5 F250 PSD SC 4x4 SD: BTS, SS 4" Exh, 6637, 6-pos chip, 4" lift, Reg. Return, FFD 160CC Single's, GTP38R, Adrenaline, Fuel Bowl Delete- 410HP/828TQ Wheel
02 Excursion 4x4 PSD: 4" DP-back w/ Aero-Turbine, Larry's Black Box, BTS
CtG is offline
post #3 of 10 (permalink) Old 07-02-2015, 03:09 PM Thread Starter
So you wouldn't recommend the misimoto or the derale.
post #4 of 10 (permalink) Old 07-02-2015, 03:41 PM
Billy Big Rigger
smoking69's Avatar
Re: Trans cooler
Tru-Cool Max LPD47391, and upgrade to 3/8 lines. E4OD case has a 1/4 NPS(NOT NPT) threads. This is a very common size for Ford and GM cooler fittings (C6, AOD, 4L80, etc.).
97 F350, 300/200, GT4202R, Twin Walbro's, sumped F26E tank, built E4OD, ISSPRO gauges.
smoking69 is offline
post #5 of 10 (permalink) Old 07-02-2015, 05:32 PM Thread Starter
Re: Trans cooler
Where can I find the bigger lines?
post #6 of 10 (permalink) Old 07-02-2015, 08:58 PM
Re: Trans cooler
I have the tru-cool and man what a difference. Never see above 165 now in 108 degree heat. Bought it from Oregon Transmission through amazon. Free shipping. Had all the hardware included. Much much cheaper then a 6.0 and as far as I can tell just as good
7.31psd is offline
post #7 of 10 (permalink) Old 07-02-2015, 10:22 PM
Re: Trans cooler
I also have the tru cool max. I bought the thermal bypass too. Very satisfied. Trans runs 150-160 towing the 5th wheel even in summer traffic
Wrench4alivin is offline
post #8 of 10 (permalink) Old 07-02-2015, 11:21 PM
Terminator Nation
Re: Trans cooler
You can just get the 4R100 SD lines and bypass. I used the SD V-10 cooler, it comes with mounting brackets that fit the OBS like it was designed to fit it.
THere have been guys who have mounted the 6.0 cooler into the OBS. There are two different coolers, one is a 28 row and the other is, I think, a 32 row cooler.
old man dave is offline
post #9 of 10 (permalink) Old 07-07-2015, 02:51 AM
Re: Trans cooler
True cool max with thermal bypass. I got it for 160 on Amazon its supposed to handle for up to 40k gvw. I replaced my radiator at the same type alone with a rebuilt trans with a lot of upgrades. That's way everything was fresh with no sediments
erstroke is offline
post #10 of 10 (permalink) Old 07-07-2015, 04:36 AM
Billy Big Rigger
smoking69's Avatar
Re: Trans cooler
I used Aeroquip socketless barbs and -6 AQP hose, works very well.
