Best 7.3 Mods - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
post #1 of 34 (permalink) Old 06-22-2015, 02:09 AM Thread Starter
Best 7.3 Mods
I am fairly new to the diesel world. I just bought a 2002 F-350 7.3 with 200,000 miles. This is my first 7.3. I had a 6.0 that gave me all kinds of issues so I decided to go with the reliability of the 7.3. This is 100% stock and has never been modded. I am looking for some info on the best mods for the truck or if I would be better to just leave it bone stock. I already plan on putting a 4 inch turbo back and a 6637 filter but am looking for some more information and advice.
countryboy90 is offline
post #2 of 34 (permalink) Old 06-22-2015, 02:13 AM
Re: Best 7.3 Mods
Also curious myself, I bought a mild modded 97 7.3 dually, bigger turbo, chipped, back pressure valve eliminator, and an OBD2 terminator scanner gauge, and few other things.
bbiljah is offline
post #3 of 34 (permalink) Old 06-22-2015, 05:28 PM
DIESEL DAN's Avatar
Re: Best 7.3 Mods
Gauges would b next.... 6 way tuner chip.
Early 99'(10/18/98)f-250,4x2,Super Cab XLT 8' Bed
MBRP 4" Turbo Back
Swamp's Diesel IDM
Grover 1700 Single Trombone Air Horn
Coolant filter Bypass W/ Napa Gold #4070 Filter
Air Intake W/CCV Mod,V-10 Trans Cooler
Stewart Warner Gauges: Trans,Pyro,Boost,
20% Window Tint
Retro Solutions 55 watt HID's 5000k
08' Super Duty Finned Diff Cover
DIESEL DAN is offline
post #4 of 34 (permalink) Old 06-22-2015, 05:32 PM
Moderator
Sbluke55's Avatar
Re: Best 7.3 Mods
Quality gauges. Isspro or autometer. Or a monitor like the cts.
6.0 trans cooler
Modded valve body and new torque converter
Ww2, bd wheel or the Riff Raff billet compressor wheels.
Then a ts6 chip or the hydra.
tylerbear946 likes this.
01 f-250, Standard
Sbluke55 is offline
post #5 of 34 (permalink) Old 06-23-2015, 11:47 PM
Re: Best 7.3 Mods
Intake, exhaust, gauges, and a tuner are the most common first mods people do. It really wakes the truck up and you will actually enjoy driving it. We can help you out with all this if you are interested.
Another wise thing to do would be general maintenance stuff. Fresh oil/filter, fuel filter, trans fluid, coolant, etc. Kind of gives you a fresh start, and you will be able to start your own maintenance log. This stuff gets overlooked a lot of times, when in reality, this is what keeps the truck rolling.
post #6 of 34 (permalink) Old 06-24-2015, 12:51 AM
Re: Best 7.3 Mods
I'm wanting stacks... but stupid expensive... cheaper then stage 1 injectors and a tune :/ lol
bbiljah is offline
post #7 of 34 (permalink) Old 06-24-2015, 11:34 PM
Re: Best 7.3 Mods
Pass on the stacks... You will have much more fun with injectors and a tune
post #8 of 34 (permalink) Old 06-25-2015, 02:47 AM Thread Starter
Re: Best 7.3 Mods
Thanks for all the info. I will most likely get a 4 inch turbo back straight pipe first and then an intake after that.
post #9 of 34 (permalink) Old 06-25-2015, 12:51 PM
Re: Best 7.3 Mods
6.0 Trans cooler
Twawsi is offline
post #10 of 34 (permalink) Old 06-25-2015, 12:52 PM
Moderator
Sbluke55's Avatar
Re: Best 7.3 Mods
If your on a budget you can just cut the muffler and cat out and install a piece of 3.5" tubing. Should run you around $50. The stock exhaust is good to almost 400 hp I believe. Your at around 250 hp now
AG Jeff likes this.
01 f-250, Standard
Sbluke55 is offline
