175 80 injectors - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 05-28-2015, 02:29 PM Thread Starter
7.3
7.3's Avatar
175 80 injectors
i just ordered 175 80 injectors from p.i.s. the other day and im having gear head retune my chip. i was wondering, how long do you guys suppose my stock turbo with the ww2 will last with these injectors? also, do you think a hpop/fuel system upgrade will be needed? i already have a built trans from diesel site, s&b intake and 4" exhaust.
7.3 is offline
post #2 of 8 (permalink) Old 05-28-2015, 08:09 PM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
Re: 175 80 injectors
turbo will depend on how many times you push it to 30 psi..will not be hard to do with them sticks....HPOP should be ok if its healthy now..i would go with a full regulated return and doing the intank mods are a must if you haven't done them already...
Ron's power stroke is offline
post #3 of 8 (permalink) Old 05-28-2015, 10:14 PM Thread Starter
7.3
7.3's Avatar
I can hit 32 psi with my stock injectors already, i didnt think it was hard on it till like 37 psi? Im not too worried about blowing it, itll just give me an excuse to get a 38r or something.
Any idea on what numbers this setup could make? with the fuel system of course.
7.3 is offline
post #4 of 8 (permalink) Old 05-29-2015, 12:18 AM
96powerstroker's Avatar
It's hard on it anytime after like 25psi. I don't see how u can get 32 out of stock injectors.
96 F250 2WD, 286K, Built E4OD, 180cc Injectors, Tony Wildman Tunes, Beans Fuel System, 3in DP - 4in MRBP exhaust, CAI, 4:10LS SCLB, Traction bars,
62 F250 4X4, 223 I6, T98 4 speed, 4:56s RCFS (Reg Cab Flare Side. Factory) 31x10.50x15s, currently on 16in Alcoas
96powerstroker is offline
post #5 of 8 (permalink) Old 05-29-2015, 12:31 AM Thread Starter
7.3
7.3's Avatar
I definitely can get 32 lol. ive had a boost gauge for over 2 years on it and with my chip in the hot tune i got 32, stock i can get 23 to 24.
7.3 is offline
post #6 of 8 (permalink) Old 06-02-2015, 11:43 PM
Turbo won't last long with that kind of fuel, unless you baby the truck. But you won't want to do that after you feel the power you have on tap.
Start saving for a turbo upgrade. 38R at the minimum, but a T4 or T4i style turbo would suite you better since they can be modified and you have many sizing options. While that kind of setup may cost more than a 38R, you will be happier with the truck. We carry the H2E and Bell HFSB turbos, both of which are T4i style. A Bell HFSB and 175/80's is a killer combo. Jody (our tuner) has run that combo and live tuned it many times. He is a big fan.
post #7 of 8 (permalink) Old 06-03-2015, 01:50 AM
and I have a t4i mount with your name all over it!
silent64 is offline
post #8 of 8 (permalink) Old 06-04-2015, 01:05 AM Thread Starter
7.3
7.3's Avatar
i wanted to go with with the bell hfsb..but i cant really push any more power into my truck than what these 175 80 injectors will push unless i do rods too... so being as im probably not going to put rods in, and wont need a bigger turbo than 38r most (most likely) that will probably be the rout i go. i really with i had forged rods cuz i woulda got way bigger injectors and turbo haha.
i talked to clay from riff raff and he said the fxr should work fine with these injectors. anyone have any real experience with it to know for sure how the fuel pressure will hold up with that? i am doing the hutch mod aswell.
7.3 is offline
