Boost - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 05-23-2015, 12:14 PM Thread Starter
01 Platinum's Avatar
Boost
I have a stock set up with an aftermarket ballbearing turbo. Nothing crazy. How much boost should I be producing. At wot I'm only getting 10 and I feel like I should get more
01 Platinum is offline
post #2 of 6 (permalink) Old 05-23-2015, 01:31 PM
Bird is the Word
Cloverleaffarm's Avatar
Re: Boost
Sounds like you have a boost leak with only 10 psi. I'd look into a leak tester to see if it's a clamp/hose etc.
E99<---Sold
07.5 CumminGs
ARP
Air Dog 2
Industrial Injection
Draconian Diesel TCM
Anarchy Diesel EFI Live
Cloverleaffarm is offline
post #3 of 6 (permalink) Old 05-23-2015, 04:32 PM
POWER Junkie
PSD POWER007's Avatar
Re: Boost
Check all of your connections on the boost side. Your preload pressure on your wastegate needs to be at least in the 22-25 psi range. On my stock turbo and 38r, I tightened the WG all the way down so that it couldn't open. I didn't have enough injector for it to matter.
2003 Ford Excursion Eddie Bauer 4x4 7.3L Powerstroke Forged
Irate T4 BASB, DIY Tymar, Full Force 180/80's, Adrenaline HPOP, Driven Diesel RR & banjos, Magnaflow TBE, GH tuned Hydra, 05 Harley's w/ HID conversion, Edge Insight CTS2, RiffRaff BRV & coolant filter, 20" Black Moto Metal, Dieselsite boots, JLR valve body, 6.0 trans cooler, ARP's
PSD POWER007 is offline
post #4 of 6 (permalink) Old 05-26-2015, 01:32 PM
DieselManor's Avatar
Re: Boost
If you have the GTP38R BB turbo you need to be running a chip at least 50HP. Otherwise you'll actually see a drop in boost. I assume you are running a chip and are not stock?
[B]David Murphy
DieselManor is offline
post #5 of 6 (permalink) Old 05-26-2015, 10:58 PM Thread Starter
Re: Boost
yes I run a superchip on the lowest setting
post #6 of 6 (permalink) Old 05-28-2015, 12:03 AM
Re: Boost
10 psi is much too low. You should be around 26-28psi with a tune on there and stock injectors. In my stock tune with a 38R, I can hit 24psi.
Boost or drive pressure leaks for sure. Pressurize the system and spray soapy water on all connections to check for leaks. Take a look at the up-pipes for any soot at the connections.
