GT4294 for DD & towing - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 10-15-2009, 12:31 AM Thread Starter
Fabricator/Mechanic
MilehighEX's Avatar
What bottom mods have you done to hold the power? What is minium with responsible driving attitude lol....boom. I scored a GTA 4294 jounal bearing, going to add a 1.01 housing and I'm going to build my own up pipes soon, and have Wildman re-burn my tunes for Jim's 238cc hybrids and this turbo. Only thing I'm worried about is towing out here in the Rockies 6,000+ elevation with approx 9,000lb trailer. How are your EGT's towing heavy and at what elevation do you tow? thanx for any input... Russ
__________________
00' Excursion 260K -170cc singles, Gearhead Tunes-MBRP 4"-Shimmed Fuel Reg.-HPX over-converter switch ,4R100 [email protected] VB & Pump Mods-PI stallion- 06' F350 Suspension-Super D60, radius arms-coils-F350 leafs- Bilsteins- homemade T4i mount & 62mm-H2E
MilehighEX is offline
post #2 of 12 (permalink) Old 10-15-2009, 12:42 AM
Re: GT4294 for DD & towing
i doubt you will ever be able to tow with it...
PMRCM#1
slowleak is offline
post #3 of 12 (permalink) Old 10-15-2009, 01:26 AM
Deputydog's Avatar
If you are towing alot, might think about the 38R..
The 4294 will do it, but you're gonna have to keep the RPM's up.
If it were me and towing my the main use for my truck at your elevation, I would not get the 4294, but instead opt for the 38R.
I love my 4294 for daily driving, but towing is a little more tricky.
Deputydog is offline
post #4 of 12 (permalink) Old 10-15-2009, 02:54 AM
6.4's are my Hero.
Reubine's Avatar
Send a message via AIM to Reubine
__________________
I'll trade ya a Fleece Performance GT40 for it, have no problems towing with it.
Reuben
'95 Ford F-350, CC,4x4,SWAMPS 300/200Hybrids,H-11 Head studs,Comp 910 Springs,Chromemoly push rods,modded TE 17*, GARRETT GT40 TURBO,built trans with 3 disc billet convertor,SWAMPS 6 position chip,3"DP to 6" single, IDM Mod,Gauges,'02 SD IC,Electric Fuel system and bunch of other stuff.
Reubine is offline
post #5 of 12 (permalink) Old 10-15-2009, 05:56 AM
urbanwheeler's Avatar
a gt40 would work better at elevation than a gt4294
'96 f-250, auto, shackle flip, solid axle, rsk, high/crossover steering, 3.73's, true trac's front and rear, trac bars, gt4202, 7.3 ic, idm mod, ccv mod, A1000, 4-line DIY Gen3, dual ipr's, casserly 350/200's, arp studs, 910's, pushrods, elec. fan, 2-stage nitrous, fluidampr.
[SIGPIC][/SIGPIC]
urbanwheeler is offline
post #6 of 12 (permalink) Old 10-15-2009, 06:22 PM Thread Starter
Fabricator/Mechanic
MilehighEX's Avatar
With the stock junk I already have to keep up the revs ie: third range locked to keep the EGT's under 1150 on the big-long passes like La Veta pass Colorado. I already smoked the trust washer in the turbo once. Maybe I might have a boost leak screwing with me. DeputyDog - What do you mean with tricky? I'm sure Spokane has some good climbs what do you pull at what EGT's. Maybe GT4294 with meth/water and 4.10's for the towing
post #7 of 12 (permalink) Old 10-15-2009, 06:36 PM
Super Hauler!
Super_Hauler's Avatar
what hes saying is your going to have turbo lag like a mofo. I tow with my 38r and love it, i tow up there where you are and up I-70 and cottonwood pass and cameron pass a lot. towing would kill you, as far as egts 1150 aint nothin i hit 13-1400* for short periods pulling 40000 gross up hills. That turbo isnt for pulling even at sea level.
Super_Hauler is offline
post #8 of 12 (permalink) Old 10-15-2009, 08:01 PM
Deputydog's Avatar
post #9 of 12 (permalink) Old 10-15-2009, 08:35 PM Thread Starter
Fabricator/Mechanic
MilehighEX's Avatar
40,000 gross I'm not towing that much just a yota rockcrawler with 1 ton running gear and a SBC on 20' car hauler. Roughly 20,000 gross loaded with all the gear. Was going trade a K31 for this GTA 4294 but It sounds like it is still going to be too big. Anyone interested in a trade for a 38R? I'm not intimitated of the fabracation part but there isn't many options for the 7.3. I hate following the path everyone else does... wanted the Excursion to be different. A grocery getter from hell!! Any one else think I could make a GT42 work towing occasionally, figured with a 1.01 housing lag wouldn't be bad.
post #10 of 12 (permalink) Old 10-15-2009, 08:38 PM
Super Hauler!
a gt40 is about as big as you would ever want to get towing. A 42 is just too big takes a lot of flow to get her to light. That would be a good start as a twin setup though.
