Best Way to Clean Used Injectors? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 10-14-2009, 07:28 PM Thread Starter
After getting screwed by an injector rebuilding shop I've resorted to putting a 60,xxx mile set of used injectors in my 2000 7.3 van. So what are some really good ways to clean the nozzles/tips before I install them without damaging the internals or electrical?
00Wildcat is offline
post #2 of 11 (permalink) Old 10-14-2009, 07:54 PM
mnstroker's Avatar
Re: Best Way to Clean Used Injectors?
Did they come today?
Back to stock for now.
Originally Posted by 1800joedaddy View Post
It's one thing to get cornholed... its another to pay for the cornholing!
mnstroker is offline
post #3 of 11 (permalink) Old 10-14-2009, 08:03 PM
HRT Performance
HotRodTractor's Avatar
Sorry to hear about your issues.
The only good way I know of cleaning the tips is to dissasemble the injector and spray brake cleaner through the tip. That will also tell you that all the holes are open and the pattern is uniform. Dissassembling injectors isn't for everyone.
2006 Dmax MPI compounds
2015 VW Jetta TDI
2006 VW Jetta TDI
HotRodTractor is offline
post #4 of 11 (permalink) Old 10-14-2009, 08:15 PM Thread Starter
yep they showed up. after searching I think cleaning is not nessesary.
post #5 of 11 (permalink) Old 10-14-2009, 08:20 PM
mnstroker's Avatar
They ran fine for me. I got around 16 mpg in my crew cab long box. So I would assume the tips are fine
post #6 of 11 (permalink) Old 10-14-2009, 08:58 PM Thread Starter
I'm in absolutely no way implying that there is anything wrong with the injectors. I am bluntly saying I never, ever for the rest of my life want to pull the valve covers off of a diesel van PERIOD! I've done it 4 times now. I've got injectors, new gaskets new harnesses, new glow plugs and just had a full set of o-rings next day aired to me. Just being careful.
post #7 of 11 (permalink) Old 10-14-2009, 09:09 PM
mnstroker's Avatar
Wasn't taken that way.
post #8 of 11 (permalink) Old 10-14-2009, 09:44 PM
jaybuller's Avatar
Just a curious ? was is Pensicola?
2000 f250 ECSB Dually 4.10s 305/70/16, 4x4 7.3 zf6 200k miles
Php hydra chip PHP tuned! 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, 160/30 sticks SB 1939-CB single clutch, home brew water setup for when i'm pulling hay through the mountains.
jaybuller is offline
post #9 of 11 (permalink) Old 10-14-2009, 09:56 PM
mandkole's Avatar
If you really want 2nd opinion piece of mind (which is very understandable with the grief of r&r), have the injectors run on a bench first. For a basic flow performance test, it takes less than an hour and the shop I've dealt with just charges for an hour of shop time. A 60K mile set should run good if well cared for.
2000 F250 CCSB-- GT4294R, 250/100s, Dahl/Fuelab, PHP, scan gauge, stock 17* pump
1994 F250 4x4 SC (sold)
1997 F250 CCSB 2wd (sold)
mandkole is offline
post #10 of 11 (permalink) Old 10-15-2009, 04:53 AM
What else?
smokyred's Avatar
You can clean them with some brake cleaner and a clean rag. I assume you're just wanting to clean the normal soot buildup off of the nozzle right?
Dave
smokyred is offline
