Electrical interferance? Space Aliens? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 04-30-2015, 09:46 AM Thread Starter
I finally got all the work done on the 2002 and put it on the road Monday as I was taking my daughter to school there is an electrical substation next to an intersection where I turn right as I pull up to the stop light the truck sputtered and quit. When I tried to restart, it sputtered but ran enough to make the turn but quit again, I coasted along the side of the road and restarted once more this time ran perfect and continued without incident all day. This happens every day this week at the same spot, here is where it gets even more strange, going the other way it barley has a small shudder. I need to shield something but what? My first thought is the wire going to the 6 pos switch but do I put a ferrite on it? Maybe wrap the wire in foil?
1996 F350 stock 350k+ miles still on original injectors
2002 F550 Swamps 175/146, tymar, bowl delete, RR
coondad is offline
post #2 of 10 (permalink) Old 04-30-2015, 09:56 AM
Kyle_KleinSS's Avatar
Re: Electrical interferance? Space Aliens?
Certainly couldnt hurt. I put a ferrite on my chip wire when I installed my hids. My truck would die when turning on my lights before I added the ferrites. They cause goofy issues so the ferrites are nice. Not sure that will fix your issue but a good place to start.
Early 99 F350 7.3 PSD Diy Intake,4 in TB straight pipe, 17* HPOP CCV Mod, Foil Delete, HPX, BTS VB, Coolant Filter, Autometer, TW Chip, TC Lockup, EBPV Brake, Tru Cool 4739 sittin on 315/75/R16 Toyo Open County M/T
03 Cobra
97 Saturn SL1
Kyle_KleinSS is offline
post #3 of 10 (permalink) Old 04-30-2015, 08:52 PM
Search for Faraday bags, they should help to protect it
Follow Hoonable:
and
btlegacy is offline
post #4 of 10 (permalink) Old 05-01-2015, 10:06 PM
fueled by Colecovision
golfer's Avatar
Garage
did you change any sensors and/or wiring with non Ford Motorcraft parts at the same time as the injector & chip install?
I've heard of identical scenarios (shutting off near power stations/big power lines) with non Ford ICP sensors in particular in the past.
golfer is offline
post #5 of 10 (permalink) Old 05-01-2015, 11:28 PM
Luddite in Charge
Mr_Andy's Avatar
Even so much as turning on the wipers is a well documented kill switch with some off brands of ICP sensors.
Mr_Andy is offline
post #6 of 10 (permalink) Old 05-15-2015, 11:02 AM Thread Starter
Sorry this has been so long in reply I am a boat mechanic so my online time has been ONLY to order parts, the rest is work til you drop every day......
I have changed the route I drive to avoid problems in the short term. I hooked up some of my gauges over the weekend and took the old route to school because I forgot and I was fine :confused Maybe that wiring bled off some interference? BTW I have not gotten the time to de-solder the switch to slide a ferrite on.
Later that day I noticed a massive oil leak from the IPS and replaced it with a BWD (from the first auto parts store I came to) Anyway I had to go by the substation once again and the problem did not occur that time either so hopefully the old one was the trouble, now I need to get a Ford one to keep in the box along with a CPS.
I did have a strange occurrence one day this week- started up at the marina, backed out of my spot, put it in drive and the truck lurched forward and the stalled engine, it was like a manual truck just dropping the clutch with no throttle. Restarted and happened again several times, tried it in reverse again and all was well I even power braked it to 1200 RPM all seemed normal. After checking the trans fluid and sitting for a few minutes thinking AAAAAARRRRGGGGHHHH,I restarted and away she went
BTW I am happy with this setup and getting just over 10 mpg in the medium towing tune so if I can get the reliability handled I will be very happy
coondad is offline
post #7 of 10 (permalink) Old 05-15-2015, 11:13 AM Thread Starter
Sorry for the double post but I didn't answer Golfers questions directly, I'm confident the sensors are all off brand but since the truck is used I just don't know for sure. I made one pass by the station without incident after installing gauges but before installing the off brand sensor and one pass with out incident since the sensor. The weird transmission thing was after the BWD IPS.
coondad is offline
post #8 of 10 (permalink) Old 05-15-2015, 02:46 PM
golfer's Avatar
Garage
transmission thing (converter locking & stalling the engine) is generally from low line pressure...but I'd have to ask our trans guy what component could make it (line pressure) intermittent
golfer is offline
post #9 of 10 (permalink) Old 05-15-2015, 05:55 PM
Had the same problem with a 50W race radio. Shut the engine rightoff. Changed the ICP, eliminated the problem. Napa part.
Muledude is offline
post #10 of 10 (permalink) Old 05-15-2015, 09:39 PM
I don't know how the 7.3s are but I'll throw this out there on my 6.0 the injector harnesses are shielded with a foil wrap inside the loom. There is a small wire with a ring terminal coming out of the loom on a rear intake bolt. I put injectors in my 6.0 once and started the nut on that shield ground but forgot to tighten it up. Every time I'd key up my cb radio with the amp on it'd stall the truck at idle or skip going down the road. During a later repair I found that loose ground and fixed it and the radio no longer affects my truck.
I don't know if the 7.3 is similar but its worth looking for.
787timc is offline
