GT4294R - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 25 (permalink) Old 10-12-2009, 11:28 PM Thread Starter
moore20017.3's Avatar
GT4294R
Here are some pics of a 94 mounted. Enjoy!
2008 F-250 SCLB Larait.
moore20017.3 is offline
post #2 of 25 (permalink) Old 10-12-2009, 11:36 PM
Busy Busy
Marty's Avatar
Re: GT4294R
Very nice... writing up some questions/suggestions...
How do you disconnect the drain line from the block? Looks like you'd have to do it by the pushlok fitting between the housings (PITA) in the truck.
Hard line looks good, but I had a problem w/ the stock H2E 5/16" line. It had some horizontal C in it to allow for some up and down movement. I replaced it with a -6 AN stainless steel line.
It looks very nice. Clean and of course the turbo is nice
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #3 of 25 (permalink) Old 10-12-2009, 11:54 PM Thread Starter
Re: GT4294R
How do you disconnect the drain line from the block? You slide the drain fitting in with hose on it and hook up the JIC fitting in the back. Although the fitting in the fuel pump hole looks like a 45* is is a modified 45 and is more like 55*. The distance there or lack of is a PITA, but hooking it up is easy! Looks like you'd have to do it by the pushlok fitting between the housings (PITA) in the truck.
Hard line looks good, but I had a problem w/ the stock H2E 5/16" line. It had some horizontal C in it to allow for some up and down movement. I replaced it with a -6 AN stainless steel line. I just like the SS tubing better, will prolly do the drain that way in time again to the new fitting in the fuel pump hole.
Thanks Marty!
post #4 of 25 (permalink) Old 10-13-2009, 12:05 AM
Village Idiot
southmike's Avatar
Re: GT4294R
Your intakes look a little restrictive , and it seems that your engine placement is a little far back
but the turbo looks sweet
southmike is offline
post #5 of 25 (permalink) Old 10-13-2009, 12:19 AM
Super Hauler!
Super_Hauler's Avatar
Re: GT4294R
ya whats up with the intake manifold? Turbo looks good what you going to keep her happy with as far as sticks?
Super_Hauler is offline
post #6 of 25 (permalink) Old 10-13-2009, 12:26 AM Thread Starter
Re: GT4294R
ROTFLMAO
post #7 of 25 (permalink) Old 10-13-2009, 02:30 AM
Re: GT4294R
Man that thing looks sweet! Now I want one. I could trade you my H2 kit, but you'd need to come up w a bit on top to make it worth my wild.
I think you should let me test it for you
How do you think that thing would run w 250/80 birds?
99 F350 CCLB
skav is offline
post #8 of 25 (permalink) Old 10-13-2009, 02:34 AM
Busy Busy
Marty's Avatar
Re: GT4294R
250's would spool that nicely.
Elkton, Maryland
Marty is offline
post #9 of 25 (permalink) Old 10-13-2009, 02:36 AM
Banning Smut
PTSUPERD's Avatar
Re: GT4294R
I think Deputydog is running 250/80s. Netted him 560 something with that turbo.
PTSUPERD is offline
post #10 of 25 (permalink) Old 10-13-2009, 02:44 AM
6.4's are my Hero.
Reubine's Avatar
Send a message via AIM to Reubine
Re: GT4294R
Looks like a very nice piece!! Would you use the water ports on the turbo too?
Reuben
'95 Ford F-350, CC,4x4,SWAMPS 300/200Hybrids,H-11 Head studs,Comp 910 Springs,Chromemoly push rods,modded TE 17*, GARRETT GT40 TURBO,built trans with 3 disc billet convertor,SWAMPS 6 position chip,3"DP to 6" single, IDM Mod,Gauges,'02 SD IC,Electric Fuel system and bunch of other stuff.
Reubine is offline
