MPG Suggestions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 04-28-2015, 01:13 PM Thread Starter
Boss Hogg
MPG Suggestions
I have read a ton of threads on here about guys getting 14-18 mpg. For the last 5 months I have been using a mpg app to keep track of the truck in my signature, The best I can get is 11.7 highway 10.4 in town and 9.5 towing. These seem very low compared to most guys on here. Any suggestions ? Thanks
2000 f350 7.3 4x4 crew cab long bed , Air Raid intake, Banks exhaust with exhaust brake, GTP38r, Boost fooler, AIH Delete, 6.0 trans cooler, billet converter, shift kit, DP Tuner, FRX, HPX, Isspro ev2 gauges on 35's
Boss Hogg is offline
post #2 of 17 (permalink) Old 04-28-2015, 02:07 PM
POWER Junkie
PSD POWER007's Avatar
Re: MPG Suggestions
What gears do you have?
2003 Ford Excursion Eddie Bauer 4x4 7.3L Powerstroke Forged
Irate T4 BASB, DIY Tymar, Full Force 180/80's, Adrenaline HPOP, Driven Diesel RR & banjos, Magnaflow TBE, GH tuned Hydra, 05 Harley's w/ HID conversion, Edge Insight CTS2, RiffRaff BRV & coolant filter, 20" Black Moto Metal, Dieselsite boots, JLR valve body, 6.0 trans cooler, ARP's
PSD POWER007 is offline
post #3 of 17 (permalink) Old 04-28-2015, 02:37 PM Thread Starter
Boss Hogg
Re: MPG Suggestions
Im not sure of the ratio but their stock
post #4 of 17 (permalink) Old 04-28-2015, 03:36 PM Thread Starter
Boss Hogg
Re: MPG Suggestions
I was thinking the stock gear ratio is a little too high for my 35's but wouldn't I get better hwy mpg if that was the only problem ? are you guys all running straight pipes ?
post #5 of 17 (permalink) Old 04-28-2015, 03:56 PM
Re: MPG Suggestions
Can u look at the axle code in the door? then post that and we can tell you what gears u have if they are OEM. You should get better mileage than that...unless you are doing burnouts from lite to lite and always driving up hill...heck my bad mpg's are in the city here in Houston and I average 16.6 but then I drive a 2wd single wheel but it still weighs in at 7140 lbs full of fuel.
have you checked your ebp sensor and tube? many claim improvement in mpg when they clean out the tube and sensor.
1996 F350 Crewcab lb 2wd auto, tommylift, now over 451k, 355k 3/31/15
1991 F250 Xtracab lb 2wd auto, sold again! Driveline and chassis is under a '65 F350 cab
1965 F100 styleside, power brakes, front discs, 390 all the goodies
2015 F250 CCSB 2wd gasser auto
2008 Mustang WIP, warriors in pink, wife's
2009 Focus, son's
aussamdad is offline
post #6 of 17 (permalink) Old 04-28-2015, 05:29 PM Thread Starter
Boss Hogg
Re: MPG Suggestions
couldn't find a door code but heres a pic of the axle tag
post #7 of 17 (permalink) Old 04-28-2015, 06:03 PM
Banned
Re: MPG Suggestions
16-18 mix and 20-22 freeway
97 psd big red is offline
post #8 of 17 (permalink) Old 04-28-2015, 07:34 PM Thread Starter
Boss Hogg
Re: MPG Suggestions
Im guessing that code is 3.73 ?
post #9 of 17 (permalink) Old 04-28-2015, 10:26 PM Thread Starter
Boss Hogg
Re: MPG Suggestions
anyone have any ideas ?????
post #10 of 17 (permalink) Old 04-29-2015, 04:26 PM
Re: MPG Suggestions
I read L73 10 5 9H06
I guessing the first number under the dirt/bolt is a 3 so it looks like it is a limited slip 3.73 with a 10.5" ring gear. Built August 6, 1999. Can anyone else confirm this?
*edit.....if you had a door tag under axle it would show C4, limited slip 3.73
others are C5 LS 4.10, C9 LS 3.55
2009 Focus, son's
