Heat coating on an intercooler? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 10-10-2009, 10:26 PM Thread Starter
I am getting ready to coat my IC pipes, turbo and up pipes. While I was at the coating shop, the owner asked if I was interested in trying a heat dissipation coating on my intercooler also. He said it's black in color and that this coating actually pulls heat out of the metal better. They have started using it on radiators and intercoolers w good results.
Has anybody tried this? How much of a difference would it make over bare aluminum? Is it worth the cost of coating?
I seem to remember something about Banks using a coating on their IC for better heat transfer also. Not that I think it's a good idea just because Gale does it, but I'm just curious if it works.
Sean
99 F350 CCLB
skav is offline
post #2 of 4 (permalink) Old 10-10-2009, 10:49 PM
Senior Veteran Member
Centxdiesel's Avatar
Garage
Re: Heat coating on an intercooler?
Interesting, Bump.
Centxdiesel
1997 F250 XL SC, 512HP 1019TQ,
30% nozzle Hybrids from [email protected]
Adrenaline, Beans D-66,Beans E-Fuel,Valair Ceramic-Kevlar clutch.
Awesome Tuning by: Matt: from:
Centxdiesel is offline
post #3 of 4 (permalink) Old 10-10-2009, 10:52 PM
PSN Mega Miler
crowz's Avatar
I can understand fins, or something that increases the surface area of an object. But I cant believe that a coating will help pull heat out of an object any better than the original surface would. Its attached to that surface in the first place. If anything adding something should make it less able to shed the heat.
2002 F250 SuperDuty Lariat PSD 7.3 Crew Cab 4x4 302,000+ miles.
, Valvoline Extreme Blue 5w40 Synthetic,
, Clifford Matrix 50.5x Alarm
, P3 Brake Controller, Swamps Injectors, PHP Tunes
crowz is offline
post #4 of 4 (permalink) Old 10-11-2009, 12:50 AM
peterbilt'in
Rob02F350's Avatar
sounds stupid to me...
i wouldn't do it... i tried to wash dust out of my IC and rad with the garden hose using my finger as a nozzle.... < not even needed to do but i was bored.
2002 F350 extended cab XLT, 4x4 auto,194K mi @ 10/25/13, ELF7405, DP F5, ultra light gauges, all kinds of "improvements" Yukon Grizzly locker 6K helper springs, x code fronts. 2 Y2K jetta Tdi. RC2 tuned
Rob02F350 is offline
