Up-pipe bellows modification - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 10-09-2009, 04:13 AM Thread Starter
Has anyone ever modified the stock up-pipes or the hypermax kit so that it has bellows instead of the donuts. I was thinking if I had some flanges to fit in place of the donuts I could weld some bellows in the up-pipes.
Or I thought you might could just weld the bellows to the collector.
Anyone ever try this or know where to get bellows or flanges. I guess a machine shop could make the flanges.
09 F450 6.4 PSD 5r110 4x4, H&S XRT Pro, Edge CTS Insight
schmity is offline
post #2 of 9 (permalink) Old 10-09-2009, 08:06 PM
Dead Member
Marauder's Avatar
Re: Up-pipe bellows modification
Why not weld up some flex pipe and keep all the oem fittings? Cheaper and less complicated. Not my stuff, just found it on the web.
He got the flex pipe at JC whitney, go figure....?
2001 F350 7.3 SD EC LB 4X4 Handshaker, Water/Meth Injection, GQSSB W/Carson Stauffer mount, Swamps 250/200 injectors, TE Duals, Fuelab/Sump, Spearco, FS 2500, Fluid Dampner, ARP head/Main studs, Sinister R/R, Detroit locker out back, etc.
Marauder is offline
post #3 of 9 (permalink) Old 10-09-2009, 08:11 PM
PHPDiesel's Avatar
I don't know why that person put flex pipe in there......it's not like he got rid of the actual problem. The stupid donuts are still there.
Cody
PHPDiesel is offline
post #4 of 9 (permalink) Old 10-09-2009, 08:27 PM
Dead Member
Marauder's Avatar
To be honest he did get rid of the "Actual" problem as the problem is the expansion and contraction of the pipe loading and unloading the donut which causes them to fail over time. You can see the wear on the pipe over time.
The flex pipe takes up the movement in the system relieving the stress on the donuts.
Marauder is offline
post #5 of 9 (permalink) Old 10-09-2009, 09:58 PM Thread Starter
Wheres a good place to get "good" bellows....not cheap ones.
schmity is offline
post #6 of 9 (permalink) Old 10-09-2009, 11:18 PM
<-- GO BRONCOS
dblamp's Avatar
You could just get these, and get rid of the problem altogether: Diesel Innovations - Products
Anthony
2002 F-350 SRW 4x4 Lariat Crew Cab, Auto, MBRP 4" T409 Turbo back, AFE Stage 2, Isspro gauges (Pyro, Boost, Trans), BTS VB, DP F-5
(No start, Modified Stock, 60T, 80E, 120race)
Democrats are tyrants.
Republicans are cowards.
Jesus Christ is our only hope!
dblamp is offline
post #7 of 9 (permalink) Old 10-10-2009, 01:26 AM Thread Starter
I'm running a set of those right now. Looking at switching to a QSSB.
schmity is offline
post #8 of 9 (permalink) Old 10-11-2009, 12:55 AM
peterbilt'in
Rob02F350's Avatar
i have to ask... for an explanation for the Need to have the Flex pipe...
i can understand heat and expand, but does it move enough to require the piece of flex pipe?
noticed the today i have some suit on the firewall...
2002 F350 extended cab XLT, 4x4 auto,194K mi @ 10/25/13, ELF7405, DP F5, ultra light gauges, all kinds of "improvements" Yukon Grizzly locker 6K helper springs, x code fronts. 2 Y2K jetta Tdi. RC2 tuned
Rob02F350 is offline
post #9 of 9 (permalink) Old 10-11-2009, 01:03 AM
PSN Mega Miler
crowz's Avatar
If I can ever reach the affording all I want mod wise I will be getting a set of those from DI.
My firewalls starting to get that sutt look too.
2002 F250 SuperDuty Lariat PSD 7.3 Crew Cab 4x4 302,000+ miles.
, Valvoline Extreme Blue 5w40 Synthetic,
, Clifford Matrix 50.5x Alarm
, P3 Brake Controller, Swamps Injectors, PHP Tunes
crowz is offline
