moving map sensor? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 43 (permalink) Old 10-08-2009, 06:56 PM Thread Starter
Ticking time bomb
moving map sensor?
i dont remember where but a while back i was on a forum and it said something about moving the map line to the hot side of the ic pipe wondering if that helps anything. I think the person said something about better throttle response. Does it work?
groomzybanshe is offline
post #2 of 43 (permalink) Old 10-08-2009, 08:22 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: moving map sensor?
It did seem to improve throttle response and a bit less smoke. I think because the PCM see's boost sooner then on the cold side.
Joe
CSIPSD is offline
post #3 of 43 (permalink) Old 10-08-2009, 08:24 PM
theSLEEPER's Avatar
Subscribing. Interesting.
theSLEEPER is offline
post #4 of 43 (permalink) Old 10-08-2009, 09:38 PM Thread Starter
Ticking time bomb
yea your the one who posted pictures arent you?
post #5 of 43 (permalink) Old 10-08-2009, 10:34 PM
CSIPSD's Avatar
I think I did at some point... I'll have to look thru my webshots. Nothing special, just drill and tap the X pipe or weld a bung into the hot side IC pipe.
Joe
CSIPSD is offline
post #6 of 43 (permalink) Old 10-15-2009, 12:49 AM Thread Starter
Ticking time bomb
any body else have input on this im thinking about doing it this weekend?
post #7 of 43 (permalink) Old 10-15-2009, 01:10 AM
PSN Pretender
907DAVE's Avatar
Did the same thing on mine, did not really notice a difference but thought it couldn't hurt. Also had to relocate my map sensor when when to the twin setup and there was a port right there so I used it.
907DAVE is offline
post #8 of 43 (permalink) Old 10-15-2009, 01:11 AM Thread Starter
Ticking time bomb
so its not worth the trouble? what kind of hp were you making when you did it?
post #9 of 43 (permalink) Old 10-15-2009, 01:12 AM
CSIPSD's Avatar
Just do it... Its the way the OBS were from the factory...
Joe
CSIPSD is offline
post #10 of 43 (permalink) Old 10-15-2009, 01:13 AM Thread Starter
Ticking time bomb
okay! what all do i need ?
