Weird idle after Edge Evo install - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 10-08-2009, 02:27 PM Thread Starter
RandysPSD's Avatar
I put a Edge Evo with the monitor on my dads early 99 yesterday. Now it has like a lope idle for a few seconds and then clears up. It does it at start up, after revving the motor, and when you push the clutch in coming to a stop. Is this normal for the Edge? I'm only used to running a DP Tuner.
2001 F-250 XLT CC, SB, 4wd, 6spd, bright amber metallic "burnt orange", CAI, 4" dual exhaust straight piped, 6" tips, wicked wheel, DP Tuner F5 chip, ISSPRO gauges, CON OFE clutch, 05 front end, 2.5" front , 3.5" block rear, 20x10 BMF SOTA's, 305/55r20 Nitto Trail Grappler
PICS
RandysPSD is offline
post #2 of 9 (permalink) Old 10-08-2009, 03:16 PM
mandkole's Avatar
Re: Weird idle after Edge Evo install
if it has the 'romps', it sounds like an icp setting glitch as it affects your truck. Does it do it with hot and/or cold oil? Have you unloaded it and reloaded it? Does it do it in all of the tunes, even stock? My obs ran fine on it, but it definitely liked the extreme file better than the race file.
These are just canned tunes and very outdated ones at that.
2000 F250 CCSB-- GT4294R, 250/100s, Dahl/Fuelab, PHP, scan gauge, stock 17* pump
1994 F250 4x4 SC (sold)
1997 F250 CCSB 2wd (sold)
mandkole is offline
post #3 of 9 (permalink) Old 10-08-2009, 06:18 PM
Coming For You
"THE DEMIZE"'s Avatar
Send a message via Yahoo to "THE DEMIZE"
My DD does it all the time its normal checked everything and made sure and all is fine. I also run the old evo with the juice and attitude.
97 F-350 cc lb 4x4
Swamps,Carson,Beans,Unlimited
"THE DEMIZE" is offline
post #4 of 9 (permalink) Old 10-09-2009, 12:09 AM Thread Starter
RandysPSD's Avatar
It does it hot or cold and in any setting besides stock.
Noticed another problem today. When you are going say 30 in 3rd gear for ex. (stick BTW). It feels like it bogs down, almost like it misses, blows a ton of smoke, for a second then clears up and goes. Kinda sounds like it's getting to much fuel. Or is it not getting enough air? It still has the stock air intake at moment.
PICS
post #5 of 9 (permalink) Old 10-09-2009, 01:24 AM Thread Starter
RandysPSD's Avatar
Ok just went and put it back to stock. It DOES do idle deal on stock. Did the programmer mess something up? It has never acted like this before.
PICS
post #6 of 9 (permalink) Old 10-09-2009, 01:26 AM
Coming For You
? not sure man but mine does it on all levels (except stock)? might run a scan on it from other then the evo.
97 F-350 cc lb 4x4
post #7 of 9 (permalink) Old 10-09-2009, 01:46 AM
Super Hauler!
Super_Hauler's Avatar
its just fuel all the egde products do it
Super_Hauler is offline
post #8 of 9 (permalink) Old 10-09-2009, 07:47 AM
PowerHungry's Avatar
If you can tell me what the PCM code is for your truck(s) I can check the calibrations and see if there is, in fact, any problem that might be related to the calibration. If there is a problem, we can make sure it gets fixed for you.
Let me know.
PowerHungry is offline
post #9 of 9 (permalink) Old 10-10-2009, 03:20 AM Thread Starter
RandysPSD's Avatar
The code that the monitor shows or the one on the PCM?
PICS
