AFE stage 2? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 10-07-2009, 03:10 PM Thread Starter
AFE stage 2?
I just noticed that on one of my trucks w the PG7, the end of the filter is closed.
On the other truck, the end is pleated and is a dry filter. Is this filter the PG5 or just a newer version?
I'm thinking that it will flow more than the first filter because it has more surface area.
Does this sound right?
99 F350 CCLB
skav is offline
post #2 of 5 (permalink) Old 10-07-2009, 03:15 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: AFE stage 2?
PG7 has the end closed, the PG5 has the added filter... I prefer the PG5 and only use the PG7 filter when the others are dirty.
Joe
CSIPSD is offline
post #3 of 5 (permalink) Old 10-08-2009, 02:08 AM Thread Starter
Re: AFE stage 2?
Thanks. I was hoping that it was the PG5. I swapped the filters and I'll keep an eye on the filter kinder to see if it moves w the PG5 like it did w the PG7.
99 F350 CCLB
skav is offline
post #4 of 5 (permalink) Old 10-08-2009, 02:10 AM
CSIPSD's Avatar
Re: AFE stage 2?
... It wont... Unless your running Garrett fuel levels...
Joe
CSIPSD is offline
post #5 of 5 (permalink) Old 10-08-2009, 02:15 AM Thread Starter
Re: AFE stage 2?
Should be OK then. I'm going to hold the boooost at 45-45#.
99 F350 CCLB
skav is offline
